Was tossing up between the cube and the golf for cheap shitty daily that I could give some epic stance.
Cube 12k purchase price with hookups, almost $6k in mods ($2k for airbag suspension, $1.5k wheels, $1k paint, panels and parts, $1k stereo, tint n all the wanky shit).
Golf $5k plus $6k = 11k which is under the purchase price of a cube. Cube is 2003 model, Golf is 2002. meh, still much more modern and reliable than a clunker of a skyline.
scroll down ya lazy kent there 1k
can you get your mate to measure the centre bore for me on those wheels, might try and wrangle em onto the golf with PCD adapters.
actually... FFFFUUU they're 17's. He can really suckadick asking even 1k for 17's.
finished installing the fuel setup on the ke70.... just need to neaten it up and put some padding under the pump to shhhh it a lil
2lt surge tank, lift pump and 044 out of leigh pidwell's 260rwkw SR powered KE....
think it'll handle my n/a 100rwkw? :P
lol funky.. yeh 17s are fine man lets u go more low.. fkn old schoolers
on a gold id be rockin negative offset 15s
post pics of 5k purchase pls
might just get these instead... should come to about $800 delivered at the current bid.
18x8.5 and 18x9.5 both +45 offset. 8.5 +20 offset gives flushness with the body on a golf, so by my calculations, if I add a 25mm hub PCD converter, it should let me clear struts arms etc, and push it out an inch, which I can then tuck in using some guard rolling/flaring and some camber.
lol actually i dunno what it looks like. I just gave money to my mate Roshan that runs Driftline and told him to snap one up that comes up at the shops or customer cars or whatevers... money talks, they are worth at least $9000 but hard to say no to cold hard instant cash.
Fucking NICE!
