man what an awesome day at the track... got to go through the Ferrari pits today... pretty cool stuff seeing F1 cars being built in front of you. Saw Button, Masa, Truli and a few other drivers ive never heard of. Marlboro corp area has such an awesome setup its unbelieveable. I will put some pics up.... if i ever get my wifes camera back... no idea what happened to it, last i recall i was in the ice bar drinking vodka then couldnt find it.
hope i do though its got some great footage and photos.
Even if you get rims with a car I'm sure the previous owner couldn't drive for shit and gutted them anyways. I've had my rims for 2 years with no gutter rash at all. Just buy new rims when you get the car.
meh.... that's easy when they're like 6" inside the guards :(
Wanna lend me your ticket? I'll become your slave!
didn't u swap my centre caps for yours kris cos yours were munted or something?
Yea the silver paint in the centrecaps were coming off. Nothing to donwith hitting gutters. I've never hit my wheels on a gutter the stock or aftermarket
Lol the wheels looked a lot more flush without the kit. Because the kit makes the car wider. Regardless of offset though if someone gutters there rims they clearly can't park or tell distance
meh.... that's easy when they're like 6" inside the guards :P
if i new how to make a signature that would be sig worthy reply of the year.
sif blags green on white i secks u seen the guy @ winton with that setup its hawt :banana:
Click the 'Wrap in quote tags" button when editing you signature.
Lol like you can talk. You got some Sydney spec wheels with crappy offset running spacers which are not safe and will cause your wheel balance to be f**ked. Not to mention the car would drive like shit with them too :P
Hmmm...
Some guy owes me money. I'm talking 4 figures.
As soon as I asked for it back he disappeared off the face of the earth. Won't answer my calls or txts, even on private number.
I wrote on his Facebook wall and he deleted it.
What do I do?
I have no proof of me giving him money or anything so forget small claims court...
Your just f**ked with it I think. Saw on your facebook. Why would u turn over goods without taking full payment? It's like going to buy a 10k car and giving the guy 5k and say I'll give you the rest next week. Even the work you did for some guy. If you don't have a contract your also f**ked. Bad news but hey. Live and learn
your on drugs just to start with
im running 18x9.5 + 15 and 18x10 + 20 no spacers anywhere.. so you can take your gay pride representing tractor and fk off now :banana:
not to mention i rkn just 1 pair of my rims are worth more then your rota's?
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
