thought everyone got the 80gb version cos it was easier to hax and more stable?
fuck, that reminds me, I bought an XBox 360 two years ago that I haven't unboxed yet.
I dunno what my PS3 is...but hasn't f**ked up yet...Only complaint is that when the fan kicks into overdrive coz it thinks it's getting too hot (even though the room is freezing cold half the time) it doesn't slow back down unless u turn it off and on again....Would be good if it kicked in until the temp dropped then went back to normal, coz it's a noisy mother f**ker
I have a Slimline 120Gb PS3.
I wanted to get the Slimline 250Gb PS3, but I guess 120Gb will do for now.
that is right, its always the ones in their suv's that speed through these zones and tailgate And dont get me started on those people in those bmw x5's :D
Fucking hate those ppl!
Does yours have a chrome surround around the cd slot? Or just plain silver?
Goodmorning from South Africa! Yes, Australia sucks balls, I know...
Durban is a great place, it's like surfers, but you can get smashed for $50-100 max :glare:
There is VW's everywhere here, I've spotted a shitload of nice immaculate mk1 golf's. So I thought I'd ask about them. Apparently, production of the mk1 golf stopped only last year!!!! I've been druelling at some I've seen.
Anyway, that's all from me, Peace out!!
Detailed Results:
Bullet Out of Foreign Customs, June 15, 2010, 9:59 am, AUSTRALIA
Bullet Into Foreign Customs, June 15, 2010, 9:23 am, AUSTRALIA
Bullet Arrived Abroad, June 15, 2010, 9:22 am, AUSTRALIA
Bullet International Dispatch, June 11, 2010, 11:03 am, ISC CHICAGO IL (USPS)
Bullet Arrival
Bullet Electronic Shipping Info Received, June 10, 2010
That was quick!
someone shot you via parcel post Pat?
yeah they only stopped makin MK1 GTI's like late last year. baller. and they had all updated electronic shiz. also for shiggles, check out merc/bmw prices.
Detailed Results:
Bullet Arrival
That was quick!
pfft had a set of wheels sent from the US in 3 days
Was driving home from work at 4am this morning on the Ring Road....On the opposite side (Greensborough bound) was a semi trailer flipped on it's side and facing the wrong way, in the middle of the 2 lanes, with no other cars etc involved....Would love to know how he managed that...
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
