kaaz 1.5
do it and you can thank me later.
shimming's good fun if you own a beat up 32, but if you want it to last, do it properly. Put it this way... ALL the power you make has to go through it. If you wanna wager that on a $1.50 shim go nuts.
shimming just increases the bite point of your viscous, which means there's still slip, as time goes on it'll wear down and cark your diff. Guaranteed. Unless you're prepared to pull down and flush pumpkins after every track day or major fang session.
Been weighing up getting a 1.5way diff or r33 gtr brakes on the car.
Which to do....
you could just drive normally, you know... like when you're not living your life a quarter mile at a time?
Which to do....
diff before brakes. GTSt brakes aren't that shabby compared to 33 GTR brakes. GTSt diff is pox compared to 1.5.
percentage improvement and smile factor is much higher on diff.
Brake Rotor / Caliper information
R32 GTST
Master Cylinder diam (mm) - 25.4 area 506.71mm^2Front Caliper Piston(diam x qty) - 40.4 ×4 = 5127.58mm^2
Front rotors (diam x thk) - 280×30
Rear Caliper Piston(diam x qty) - 38.18×2 = 2289.78mm^2 ratio FR = 2.239
Rear Rotors (diam x thk) - 297×18
total 7417.36 brake to master ratio 14.63
R33 GTST
Master Cylinder diam (mm) - 23.8 444.88mm^2Front Caliper Piston(diam x qty) - 40.4 ×4 = 5127.58mm^2
Front rotors (diam x thk) - 296×30
Total area 7417.36mm^2 brake to master ratio 16.67
R32 GTR (Non V-Spec,)
Front rotors (diam x thk) - 296×32
R32 GTR V-Spec / R33 / 34 GTR with Brembos
Master Cylinder diam (mm) - 26.9 568.32mm^2Front Caliper Piston(diam x qty) - (44+3Cool×2 ... leading pistons smaller then trailing 5309.29mm^2
Front rotors (diam x thk) - 324×30
Rear Caliper Piston(diam x qty) - 40×2 2513.27mm^2 ratio FR = 2.1125
Rear Rotors (diam x thk) - 300×22
total 7822.56 brake to master ratio 13.76
This is the ratio of master piston movement to overall brake pad movement
R32/GTR calliper ratio 15.43
R33/GTR calliper ratio 17.58
So there isn’t much difference between the Brembos and the std Nissan R32/33 GTST calipers and R32 GTR callipers
Oh...and an old favourite that seems to be a good practical test of what the theory suggests....
Car & Driver did a test a few years ago ...Test Car was a WRX (US Spec which only uses two piston sliding caliper, not as good as Nissan 4 spot or later Model WRX 4 pots)
So tested kits were, std car, std car with upgraded pads and fluid, Brembo F50 Kit, Brembo Lotus Kit (Similar to as fitted to GTRs, 44/38mm pistons), Stoptech it and Prodrive Kit (Alcon)
Stopping Distances 70mph - 0 , 3 Stop
Brembo F50;_____________ 185 / 183 (Average / Best)
Brembo Lotus; ______________ 200 / 196
Prodrive; __________________ 198 / 194
StopTech;__________________ 187 / 186
Stock; ____________________ 205 / 196
Stck with pads and fluid; ____187 / 184
The above figures are all in feet, one stop difference between pad and fluid upgrade to crappy sliding caliper brake setup and massive Brembos is 1 ft...lol 30cms And over 3 stops the average is 2 ft...lol 60cms
So you can see the one stop max of the upgraded pads and fluid is damn good when you consider the $$$ to % difference.
Stopping Distances 100mph - 0 , 25 Stop
Brembo F50; _____________ 299 / 288 (Average / Best)
Brembo Lotus; ______________305 / 294
Prodrive; __________________ 308 / 295
StopTech;__________________ 297 / 290
Stock;_____________________ 340/317
Stck with pads and fluid;_____316/299
Not the world of difference you would be led to believe by the "you need 6pot caliper 343mm rotor crowd."
Specs of the kits:
Rotor Weight (pounds) Size in inches (diam / thk)
Brembo F50;.................15.8......................... .13.1 / 1.3
Brembo Lotus;..............12.9.......................... 12.9 / 1.1
Prodrive;......................16.5............... ............13.0 / 1.1
StopTech;...................13.9.................. ........12.9 / 1.1
Stock;.................. ......14.2..........................11.6 / 0.9
Caliper Weight , Piston Size, (mm)
Brembo F50;..........8.6 pounds...........40 / 44, Leading / Trailing
Brembo Lotus;.......6.8.......................36 / 40
Prodrive;...............9.1..................... 34.9 / 41.3
StopTech;.............9.3.....................36 / 40
Stock;.................10.8.................. .43 / 43
...and COST!!!
Brembo F50;.......................US$2,995
Brembo Lotus;.....................US$2,595
Prodrive;.............................US$1,999
StopTech;...........................US$1,695
Stock with pads & fluid;....... US$130
R32 GTST
R33 GTST
Front rotors (diam x thk) - 296×30 Different caliper to R32 GTR but same disc diameter.
R34 GTT
Front rotors (diam x thk) - 310x30
The calipers that suit larger diameter discs have longer mounting legs to space the caliper out further.
quote from: Brake Rotor / Caliper information - GTRCanada - Canada's premier skyline enthusiasts club
hmm fair go, will look into diffs
The ford rim spec, I don't have a 33.
33 waslike $1500 full comp agreed value of $25k and heavily modified (all mods listed)
i see. what ford is that?
mmm the new xr6 turbos black on black with the red brembos = tuff
Edited by R-SPEC
isn't that the dude in canada who converted his R32 gtr to R34 look using factory replacement fenders stitched in n stuff?
lol nfi, thats the only pics i stumbled across. Apparently he did it in order to have the ultimate handling for his r32 gtr.
R32 GTST
R33 GTST
Specs of the kits:
...and COST!!!
R32 GTST
R33 GTST
R34 GTT
wow you made a huge fuckoff tl;dr post to say exactly what I said in 10 words 15 mins earlier. gratz.
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
