My mechanic was insistent that it would work better with the clutch I'm getting. So I just told him to go for it.
I was going to get one anyway. Less drivetrain loss :)
Car is predominantly a daily, but used for hill climbs and track days too.
Trying to get a good balance between looks, performance and practicality/reliability.
flywheel is a waste of money
I dunno, didn't really like the feel of my Exedy HD, so thought the cushion might be a good change. Spur of the moment thing :P
haha the cushion button isnt all that good for daily driving :P
takes a bit of getting used to, Kris drove my old 32 with the cushion button and even he said was hard
took alot of abuse though, and only died when one of the springs popped out of the centre part, apparently its a common issue on them
Haha good call. He's actually not making money off the clutch. That's the price that his wholesaler gave him. It's a bloody good clutch though. Definitely overkill for what I need but meh :P
HDCB's are terrible for taking constant abuse (like a full track day). The centre and the ceramic are attached so you can't rebuild them modularly when they wear out, they suck for daily driving and are no more durable than a regular HD.
basically HDCB's are for people who want to feel like they're using a brass button without any of the durability or benefits.
You either buy an HD which is cheap to maintain, gives good grip and slips enough to daily drive, or you get your balls in a bunch and buy a brass button. HDCB is for fags.
Heavy flywheel + snappy clutch = good
Light flywheel + snappy clutch = shockloaded drivetrain
I run an exedy lightened wheel in mine, with a 5 puk. Love it.
Fantastic for track work. Doesn't get driven on the street a whole lot, but when it does its a ball.
To be honest I didn't notice the difference between gears, there is a definite pickup in revs while while under load though.
leigh fix coilpacks and then check it, if the coilpacks misfire i wouldnt bother trying anything else. Where do u live? Do u want me to check it
yeah i'll wack coilpacks in first and see how it goes. I live near Knox but yeh will see how the new coilpacks go first
this.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
