We charge 7.7% as standard we negotiate where we have to very rarely do 5s so yeh I'd say it's a good rate we are expensive from what I hear but thy got good systems in place so guess people get service they don't mind
ah nice. She told me its a low rate and offered me that much because i purchased the place from them. Cheers for the insight.
If anyone is up for a bit of live streaming electro/house/tech:
http://www.kissfm.com.au/kissfm_mp3.asx
For the next 40mins or so. Guy i know is playing, some good beats.
oo didnt know this station existed.
Could only find 89.9fm Lite FM (christian radio) on my japanese radio or 3AW on AM :(
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
