Yeah man!
I'ma on VIC too.
Probably seen you / your car at a few VIC meets at Garage Cafe.
Are you the guy who's always there with his girlfriend? I think I remember talking to you. My car was there at the last meet so you must have seen it.
GT-T stock seats are probably the cheapest looking seats in the skyline range too, never liked em
Really? I put some R34 seats in my R33. Much nicer looking and more comfortable. R33 s2 seats are so small and crappy.
Pretty much this, I hate my s2 33 seats and I've been looking at doing 34 seats.
R33 Series 1 GTS-T seats ftw...these are the best and warmest looking IMO. Don't know why warmth is a factor lol, the cold air must be on my mind.
yeah i dont know why the changed the seats in s2 - the s1 seats are decent and dont look like ass as much
also yes they is fluffys!
yeah i want some nice bride seats but when i get close to saving enough up - ill end up wasting it on some other mod
at the moment im thinking of just going for these
just because i hate the s2 seats so much
and damn they only $600 new
They don't bolt in though do they?
http://www.skylineowners.com/forum/showthread.php?t=117083
Just gotta work something out for the rears.
HR31 GTS-X seats are the comfiest Skyline seats.
Prove me wrong.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
