34R / Eastbear seats are ok for track work. They allow you to still have feeling in your ass once you arrive at the track as well.
32/33 are almost useless as the shoulder wings are not large enough.
And get some KU31's they own in the wet from all reports. They cost more than KU36 for a reason....
How is your car now Hamish that is sounds like s Saab wagon?
+1 for no shoulder support but they fit my bum great :) its also handy not having sides when you have to deal with a ballin kid in the back
+1 for KU31s got a full set for the misssus car for 540$ and they are great in all conditions and they ride is really nice and comfy to...will be better when I get my koni yellows from the states, 600$ for a full set = win
dont do it!! I have em on my car pretty good in the dry shocking in the wet!!
i would consider another tire since its winter and aint gana stop raining
jus sayin have a read on them :thumbsup:
that's just a load of shit.... ku36's are nowhere near as bad in the wet as people say.
for some reason people buy 36's and expect the performance of an RE55, it's NEVER going to happen
they are NOT a semi slick tyre, they are just a street tyre. they perform fine in the wet for what they cost/are. and yes I have used them on many occasions
i should know in less than a week :)
volvo motor FTW
volvo motor FTW
I dunno about you guys, but I can't buy or consider buying performance/sports cars I've beaten in run ins with my near standard R33. They just seem to lose their appeal after that. MPS, XR5 Turbo, Golf GTi, Cooper S, list goes on. Makes me think, why bother buying one of these when such an old car will just do away with it. Not saying the new cars have to get faster and faster, but they better have something special to offer and above a 15 year old Skyline that's all. Aesthetics and fuel economy maybe? A better feel? Not performance though...
there all phag ass cars anyway so why would you.
personally i like luxury over performance for daily duties
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
