The jap (boss) way of fitting catchcan setup to RB20's. Two catchcans like a boss. (what does the jap say?)
1st catchcan separates oil from blowby gas and drains oil to sump via a drain under 1st catchtank (green line in above photo). The 2nd catchcan catches left over oil (if any) and clean blowby gas (no oil) gets sucked back into intake pipe infront of turbo from 2nd catch tank.
That person with dual catchtank setup on his RB20DET always had a problem with a single catchcan filling with oil and had to pit every 2x laps. The addition of 1st catch tank was the solution, where oil drains back to sump and engine doesn't lose oil. Loss of oil in sump could could have resulted in oil starvation, engine failure. Also he doesn't have to pit every 2x laps.
Catchtank size is important due to blowby gas slowing down enough, so oil can be separated. Catch tank size is based off capacity of engine (amount of blowby gas), so catchtank varies in size from a RB20 to RB30 engine.
You'll see a dual catch tank setup on Mines R34GTR. Now you understand why it has 2x catchtanks and why the catchtanks are a certain size. Mines go one step further by fitting baffle plates to cam covers to separate oil from blowby gas before it exits camcovers.
Mines have copied others that having been doing the 2x catchtank setup since the 80's on Group-A RB20DET racecars, Group-A R32 GTRS, etc, but modified it slightly
Guest
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
