You really think so? I found my 595's to be great. I was never lost for traction when I didn't want to be and they gave me some great launches on the skidpan. Just need to see the test of time now, but for 167 a corner, great value even if they only last 20,000km.
  • Replies 149
Its a matter of trying them and seeing how much better they are.
Sure for the money 595s are great, but if you want ultimate traction in a street tyre theres plenty of other options not too far from 595s pricewise.
I've had a second hand set of Conti SportsContact2s on the fronts for DECA and I was very happy with the way they performed.
If they were that good second hand, i'd like to see how they'd handle like when new.
I had the least understeer with these tires this DECA then any previous DECA i ran with different tires.
I'm running the same KU36's on the s14 as Rus and a big big fan of them.
def better than the 595 SS and the older RS.
that said I will be moving to the newer 595 rs-r when this set gone from those I spoke to def the tyres to run.
M
Me too, I ran 595's at the recent DECA and thought they were good for traction and with cornering.
What pressures are you running in yours?
Not sure what pressure, I haven't checked them since I had the tyres fitted to the wheels (couple weeks ago). Probably about time I gave them a pump :(
Admittedly I haven't tried the others you suggested but I've judged these ones against high end street tyres ($250+) that I've tested in the past and they came up pretty well IMO. At the same time my car is only producing 165rwkw so when I launch on boost I don't need a huge deal of grip to get moving.
Awesome Day!
So good to cut loose off public roads.
anyone know where we can find the footage from the legendary dude that was sticking the camera on the side of the cars?
also people having problems watching this:
'I have put up some in-car videos: http://www.youtube.com/user/tekjim#p/u'
OK Ladies!
Results are HERE
Great work from Russman taking out the win overall!
Also notable mentions for the little Lancer and MX5 getting right up there against the "big boys" :blink:
Other than that good work by all.
I Had a great day even though it was bloody hot standing out there on the long wang.
I will say though, its very interesting to see the difference between the fast and the slower times in the way people are comming into those stop gates.
I was on the long wang but I imagine that it goes for all the other gates during the day.
On that long wang finish, some of you guys could have knocked off sometimes up to 5 seconds I reckon if you just attacked the finish gate a little harder!!
In most cases that would have moved you up from mid-low field right up within in a couple of seconds or so of the front runners.
Somthing to keep in mind for next time :(
Also thanks to Tim, Shane, Mark & Russ for rides during the battles!!
Enjoy!
Looks like another great weekend. Shame Icouldn't be there. How was the after hours shenadigans?
I'll have to get the car down for at least 1 this year. Frysie, I hold you personally responsible if I don't get down there!
go Russman! and also well done to the Clive in the Lancer for taking out the highly contested "NA challenge"..
some of my times were slower in my second run compared to my first run... usually it's the other way round for me, something to improve on for next time I guess.
p.s. for Pat: Z32>R32, 3.0L>2.0L and NA is best :(
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
