Looking good so far!
Interesting about the boost control/spike. Perhaps they aren't 16psi?
Seen many turbosmart ones say "X" and varied by a good 3-4psi when on the car.
Soo surprised it comes on at almost the same time as -7 size turbos, makes twin turbos look like junk
Loaded up on a dyno -5s and -7s basically "come on" at the same RPM on a dyno interestingly enough, yet they are a good 60-70rwkw different up top.
Drive them on the street however and its a different story that you don't get on paper - been there and done it with -9 to -5 :)
It depends on the pressure and also the piston location in the manifold. Apparently Turbosmart guarantee it will hold the stated boost due to countless hours of bullshit bullshit testing. Perhaps on their test jig, not in the 'real world'.
I am interested to see what my new 26psi springs turn out to hold. Hopefully I have time for a squirt tomorrow.
Gonna have a play with it in the morning :)
Yes gate pressure, i agree 100% about the springs. But i cbf'd changing them. Just made it a bit ah touchy tuning it as i cant work up from low boost.
Ash- no extra loading on my dyno it has a set 2second preload and i start all runs at the same speed. I agree with transient boost response on the road tho. Deano and i can test the rolling starts :) -5's vs 6262
yea paul, its all standard, its even the factory fuel lines, and rail just with id2k injectors and the plugs rewired. Oh his got cam gears on it.. but thats not out of the norm.....
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
