Thanks mate!
Ron: the SR is good for about that 280-300kw mark. Its just about control factors. If on 98 a little ping will do a lot of pop at that level, but if tuned safely (like on E85) they are pretty OK.
For reference my 'built motor' is nothing but a refreshed stocker with forged pistons. Im reusing the crank and rods and aiming for a motor that will never see more than 350 even if I do go crazy in the long run. It will probably never see over 300 in reality.
Because the last tune was close to 430 RWKW. Different head and a few different mods I wanna see what these little things can do. They should crack 450 without too much trouble.
-5's aren't too bad, A Z32 at Unique Autosports just cracked 447rwkw on 21psi and pump fuel with them.
are you saying someone nearly cracked 600rwhp with -5's at 21psi ??
From what he's said he has 3" Intakes on the turbos but they are run of the mill -5's apart from that.
http://www.aus300zx....2&postcount=358
Edited by Super Drager
Thanks mate!
Should go a td06sl2 20g 8 cm but with billet compressor wheels
Transistient boost response will be better and get maybe 10kw more up top
Hypergear can get them or gtpumps or you can get kando to make one as kamak is making billet compressor wheels now and kando get there turbos from them
I think you'll find they're 2871R's or -10's from my conversations with John from Uas who is building on it.
Could have misunderstood though.
Nope, take a look at the thread i posted. GT2860-5's. There is a Z32 that was built with GT2871R's though, he put down 467rwkw.
Have you seen any results of any of the above turbos vs billet wheeled versions?
my PT6262 .84 TS will be arriving this week hopefully, should in interesting. I havnt seen anyones results on this forum using one with this setup (25/30 with vct).. should be neck breakingly responsive ;), and if it taps out too early, well.. only $285 for the 1.0 housing to be sent to replace the 84 and try again.
Eagerly waiting results as this was the same path I wanted to go down! :) Built motor? Is the 6262 Gunna be pushed hard mate?
Just had a result sent in from a SR20det customer made 282rwkws. That is our billet version, don't want to hijack the thread, check out dyno readings on my thread.
I have a billet 7175 (.94 single entry) on a single cam rb30. With a powerglide.
It's as responsive if not slightly better than a 35r (1.0x). Makes 549hp@28psi on e85. Trapped 138mph. Keen to feed it proper boost soon and see how it goes :)
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
