not suprised, being auto...my 4294 with a .91 T6 housing wasn't any laggier than a 3540 1.06 on a RB30 single cammer really with a auto
only a split second was a 3540 better and then the 3540 got fiercely trodden on...
Edited by jet_r31
agreed that drag+auto = a totally different ball game when it comes to response. its got very little in common with response on a street or circuit car.
have had a 3076 on an old school 4 pot feel as responsive as a T25 SR with the right cam and stall combo. easy to do, just useless around a bend.
I had a 35r on a 6boost mani, I changed to a new 6boost mani and 7175, and it is more responsive In every way, makes more power earlier, power doesnt drop off, and builds boost on the tbrake significantly faster....
Must be moving on from older technology that did it...
Eagerly waiting results as this was the same path I wanted to go down! :) Built motor? Is the 6262 Gunna be pushed hard mate?
yea fully built 25/30, will be pushed hard eventually ;). Just dummy fitted the hot side tonight.
Uploaded with ImageShack.us
Edited by SilverECR33
Tossing up between a 6262, 6266 and 6466 on a stock capacity RB26... Looking for good response and 400-450rwkw on moderate boost 20-25psi
T4 0.82 divided rear... Want most of the boost all in by 4000rpm
Also is everyone just going journal bearing or running the ball bearing? I don't mind the extra cost if it's worth it
Well after Jez's result on his standard 26, it'll be hard to go past the 6262. He made 402 at just over 20 -21 psi IIRC.
I've seen some photos of the 66mm cea turbine next to their older stuff... I'd be highly tempted as the aero looks great.
Question in my mind is 62 vs 64 compressor in terms of lag. Id be tempted to just go a 6466 for the headroom, coz u know u will end up with a dirty 30 lol
When I was comparing my 6466 to a 6262 a few weeks ago, the angle on the blades looked a little different but also the gap between the blades on the intake were signicantly more of the 6466. Both were CEA's
Hmm thats indicating its more than just a change in trim, the 64mm comp must have a way bigger exducer than the 62mm so its more or less an entirely difference turbo.
Like comparing a 3076 and 3082 I guess. Same stuff, different application entirely.
A link to a page with comparison to old tech 65mm wheel (I think the 62mm turbine is same tech) and compared to new 66 CEA turbine:
http://realstreetperformance.com/store/precision-billet-cea-6266-turbo-750hp-turbocharger-2709.html?zenid=59df912a5cff403c6491d3cf5176bc7c
FYI both 6262 and 6266 are rated as 700HP items. I'd be chasing that 66 CEA item, better tech is where its at.
Finally got the 5558 in today, can I use any 3" v-band flange off ebay (exhaust/dump side), and what oil line/fitting did you guys use - do I just go to Pirtek/Enzed or get an ebay jobbie - re: Kando lines fit? I am not sure if you just connect the oil line to part way in the existing line or get rid of existing and new one straight to block? thanks :)
    • Hi everyone, I'm about to complete my first single turbo conversion on my R32 GTR and I thought I would post the step by steps that I will be following. I will list the parts I have / the parts I will be buying. I will be redoing this guide after I have completed the conversion. Parts list: - 3576 turbo 0.82 v-band (coolant and oil)  - v-band top mount turbo manifold - 50mm wastegate - manifold copper gasket - titanium manifold stud kit - turbosmart 3 port boost solenoid - link can lambda kit (wideband) - link ECU - radium 12AN push in valve cover fittings (pair) - hi octane catch can - 3.5inch downpipe - screamer pipe - pipe from turbo to intercooler - intake pipe setup - power steering relocation kit - oil drain block off plate - coolant and oil lines Now onto the step by step guide (please add / correct me if there's anything I missed: 1. remove fluids, twin turbo pipes, pod filters and afm's 2. remove the factory coolant hardlines from the hot side. 3. remove heat shields  4. remove the downpipe 5. remove turbos and manifolds 6. remove factory manifold studs 7. clean whatever mess you have made 8. install power steering relocation kit 9. install new manifold studs 10. install new turbo manifold with gasket 11. install new wastegate with screamer pipe 12. install new turbo  13. install new coolant and oil lines  14. install rear oil drain block off plate 15. stop and appreciate that you now have a single turbo in your GTR 16. wipe away tears of joy and install downpipe 17. install the wideband sensor into downpipe 18.install pipe to connect turbo to intercooler 19 .remove stock boost solenoid  20. install new boost solenoid 21.  install intake setup 22. setup the rest of the can lambda kit with the ecu  23. refill fluids and hope for the best 24. ask forums for help with issues 25. fix issues 26. drive your single turbo swapped r32 GTR into the sunset. Doneeeeeeeeeee. Now I know this isn't detailed at all but I will be doing that when the conversion is done. I will be posting pics and any helpful details i can and ill make sure to fit in as much information as I can. If there's anything I should know before i do this PLEASE let me know. Stay tuned for what's next. Thanks...
    • I have wasted too much time on this, more than I am willing to admit. I hope someone can set the record straight for me.  I want to replace my Nismo (non GT pro, non GT) standard 2 way in my R33 GTST with a 1.5 way... Ideally I want to get an ATS 1.5 way Carbon LSD, but I don't want to reuse my 29 spline 5x1 axle stubs, and new 30 spline 5x1's are impossible to get a hold of ($$$), and I don't want to drop the cash on going to 6x1 stubs and axles ATM. Which leads me to the Nismo GT Pro 38420-RSS15-B5 or RSS20, as they come with new axle stubs meant for the diff, and is "Convertible" from a 2 way or 1.5 way to "Other ways", but that is where I am stuck as the documentation is a bit all over the place.  To sum up what I have found I believe the all the Nismo GT Pro PN's are convertible from 2 way, 1.5 way, and 1 way; but Nismo sells 2 skus (2 & 1.5) so people do not have to disassemble to convert it.  I found this thread on 350z but it left the question unanswered. https://my350z.com/forum/engine-and-drivetrain/620032-nismo-gt-pro-lsd-1-5-vs-2-way-and-torque.html  Essentially the way I think it all works out is like follows...  2 way  1 way  and 1.5 way would be the center pinion shaft in the 1 way block, but with the with the center flipped 180*. So the ramped side of the pinion would face the 1 way gate and act like a ramp.    I can only get my hands on the 2 way in the states, and I am not trying to get stuffed on tariffs by ordering from Japan or anywhere else. I want to confirm that if I get the 2 way I can convert it to the 1.5.
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
