what have you got in the pipeline now the vet is for sale PJ? something bigger?
I thought about a turbo V8, but realistically it would throw the handling out and I want to do some track days so going to stick with what I know, if it sells.
I was looking on the precision site and was wondering if anyone has managed to install 2 lowmount billet turbos into a gtr? Would be an interesting step from the good ol' garrett -7, 9 and 5s.
The gtx versions look great too as low mounts but precisions great results seen so far would be very interesting to see.
What turbos? it's all good to low mount them but it means custom intake and exhaust sides. Mega effort!!!
the main issue is picking the right ones to low mount, so all that mega effort doesnt get wasted : D
Looking at the 4828 400hp unit, not sure if it would fit and im sure it would require alot of work but there are always some crazy builds where someone wants to do something different.
Just looking at the gtx2860 thread and the r34 gtr build; having to buy a set of -5 turbs to modify and welding the snout and outlet. Hopefully there will be some bolt-on options for these turbines if there is enough demand.
These precision units are sooooo tempting for me; the 6262 was on my mind but i settled on the -9s because of the stock look.
Im very impressed with the powertune r34 gtr and the drag s13 silvia from motive dvd....amazing!!!
I don't know if it interests you, but I've spoken to hypertune about a low mount twin gate manifold. It's little in your face than a high mount and will make plumbing the gates in easier.
wow, would be similar to the manifolds used by twoogle right? great for people who wish to make big power using twins; would say it was kinda a lost cause considering how simple it is to buy a 6bob manifold and that the gt-rs/-10 turbos arent the best in many peoples opinions.
this is why im interested in these new range of turbos like the gtx28, precisions billets and perhaps borg warner units in development.
for myself, im sticking with the stock rb26 manifolds but in the future when I do a rebuild, i would want these options
cheers mate
cheers mate
Paul's low mounts, he used standard ported manifolds with his 2530's/RS setup?
I have a 6466 on an rb28, and i expect in excess of 500awkw. Might be a little bit too extreme on a daily strees sil. Buut, look at PJ's THING, because thats what it is, a freakish THING. It has a monster and still makes powers that are usuable for speeding up the rotation of the earth arouns the axis of the suns, and stuff
i love this post.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
