I run a 6266 .84 T4 split pulse and made 352rwkw on 21psi that was with E70. Full boost about 4800. Though my Turbo is the Journal bearing one. If you buy BB alot more responsive around 4300rpm. 6266 is good size for 500kw with e85
Big difference between 600 or 700hp? I understand this came for a good price but obviously you aren't happy with it and the car has been built around this turbo now (exhaust cooler pipes etc) if 600 and a bit is your goal and you like response go a 6266 with a 1.0 rear. Your motor will love the larger turbine it will feel nicer down low off boost and it will make 600-650hp quite easily!
Are you on stock capacity? If so a .84 wont be too bad. But obviously you are gunna be leaning pretty hard on a stock motor chasing those numbers.
If your motor goes bang would you stay 2.6 or would you go stroker? If yes to stroker go the 1.0 if happy with 2.6 go .84
Edited by Mick_o
  • Like 1
i already had a 3.5" tomei exhaust on the car, 3" dump no cat, cooler, pipe work all came with the turbo. sweet im just chasing info at the mo as ive read this thread a few times over since i put this turbo on. yeah shes still a 2.6 if she goes ill be looking at going 2.7 or 2.8. i know she'll get leaned on abit on a stock motor to make those numbers but she is my daily driven car and the occasional track/drag day. for the time been 600 would be the most but once built 700 will be my goal
Edited by cliptonz1
Hey mate, i saw you were selling your turbo on facebook and was going to comme t but didnt want to f**k up your sale.. 20psi @ 5000rpm does not sound right
I use a 6466 Gen2 with .82 Vband single entry housing on my built RB26, which has a Nissan 2.6 crank and HKS 272 10.2mm cams
On E85, it makes 30psi by about 4500rpm, and makes 710rwhp
I would highly recommend this to anyone.. it has less lag than my previous 2860-5 setup, which i personally did not think was laggy.. but theres no contest when compared to a big single, it comes on like an absolute motherf**ker
  • Like 1
  • 1 month later...
34 minutes ago, ohno1 said:
I reckon 1.00 will be too large on a 2.6
Read my mini review of my setup a couple posts up
Cheers mate.
I was reading the thread for about half an hour. Must of missed the last page..
I have a 1.0 on a 6766 that's bolted to a 2.6 and its fine. E85, 272/264 9.1mm cams and a decent amount of head work and I don't think its laggy at all. I would see full boost (currently 23psi) no later than 4500rpm
  • 1 month later...
Ive decided to go with the gen 2 6266 with a t3 .82 rear on my basic built 25 (cams,springs,studs and forged).. I already had a manifold otherwise i would have liked to go the .82 T4 twinscroll.. but none the less ill be pushing it and hoping to post some decent results in the coming months.. the decision between the 62mm and the 64mm was tough but i decided to go with a slightly more street friendly turbo as after RW17 it will be mainly used around town...
  • Like 1
  • 1 month later...
So many posts to go through and not enough time :(
So what are people making nowadays with a 6766, 1.0 split rear on E85 on a stock stroke RB26?
My girlfriend seems to think her car is a bit of a nugget and I want to prove her wrong. It runs 138mph in full street trim and makes 485rwkw at 23psi on the Unigoup dyno which is a pretty tough dyno from my experience
Not sure about 6766 but my brother Inlaw, who bought my previous Gtr went 6466 1.00 and maxed the turbo out on his setup at 553kw at 40psi
built 2.6, mild head/cams, 3.5" exhaust etc on United e85 tuned @ Jez .
  • 3 weeks later...
Hi, I am currently still two Td05 g18 billet turbos. I would also like to switch to a singel Precision Turbo.
My Setup:
 Build Rb26,
ported Head,
Oversize Valve,
270cams 10.8 mm,
Revlimit: 8500,
1000cc Fic Injectors,
Walbro 450l Fuelpump.
Fuel: 102 oktan,
Boost max 30psi
I want to more than 800hp on the Flywheel.
I do not know which turbo I should buy. The 6466 bb or the 6766 bb? And if what ar? I apologize for my bad english :)
Edited by Ersatzreifen
Well. On a near stock head with a quick home port job, stock valves with 80lb springs and a set of drop ins i made near enough to 550awkw on a 2.8 with a 6466 with 84 rear. 4 inch dump was at 49psi. The turbos like to be run hard.
Grab it by the pussy
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
