24 minutes ago, SimonR32 said:
Direct back to back change... Same boost, 30psi
6870 made even more power with extra boost while the 9180 was all out
Yeah not too surprised that the EFR9180 was out, I would 100% expect the 6870 to outflow it - and by a bit of a margin.   The boost threshold however is a definite surprise.   Interesting how some results can vary!   Hard to know what to make of it.
On 4/25/2019 at 2:27 PM, SimonR32 said:
The precision is the ones that comes on way earlier and makes more power...
I'd like to see the transient response make up for that deficit
Which rear housing was on the efr?
  • 3 weeks later...
Hey all,
Bit of an update from late last year.
Precision 6062, built s1 rb25det, e85 etc
Got it tuned last year and it made 431kw @26psi apparently the turbo was maxed out. Dyno dynamics roller dyno.
I decided to change the wastegate springs from 14psi to 21psi, fixed a boost leak i found underneath the intake manifold ( idle control- cold start valve area ), hpi evolve radiator and decided to run a viscious fan again.  Might have been a few other minor changes.
We stopped at 29psi as we were a little worried about the arp 2000 headstuds not handling much more. Turbo seemed to be still going and I think we could have gotten a bit more out of it if the headstuds weren't a limiting factor.
This is on a mainline hub dyno so it is 710hp at the hubs. Still quite happy with the result and I'm sure the 6062 could keep pumping. I attached a video of the run, hopefully it works.
We used Real Dyno hub dyno and Brad Sheriff from Boost Automotive Tasmania tuned the car.
  • Like 2
  • 2 months later...
38 minutes ago, reaper said:
Nope haven't seen anything. I'm trying a 7275 this week and will compare to my old 6870.
What was the 6870 like? I know I could search this post but who the hell knows how far back I may need to go to find a post....
I have a 6766 with a 1.0 rear and I don't know if the lack of driving but its started blowing blue smoke the other day. highly unlikely to be the  engine so it might be time to up the turbo a little
4 hours ago, feedmyfast said:
Hi Guys,
sorry it has been so long. here are the results from my 6466 @40psi. The car is a different animal now, had to get some drag radials to put down the power.
What's the rest of your engine setup?
I also have a 6466 to go on mine.
S1 RB25, Kelford 270 cams, supertech valve train (stock sized), CP pistons (stock bore and compression), Manley rods, balanced crank/ block. Otaku manifold, ID2000s
  • Like 2
6 hours ago, feedmyfast said:
Hi Guys,
Have you raced it? what mph did it run if you have?
Edited by ido09s
Hi Guys,
Ha! That is ridiculous, nice work!  That's gotta be one of the more stout RB25 setups out there, being SAU people will probably make dyno comments but realistically - an RB25 with 270deg cams and 40psi pumped through it on E85 is going to make some serious power :)
What is the spool like?  There is no rpm scale on the dyno plot (NFI why people print plots like that), so a bit hard to tell.   Be very interesting to see how it goes at the strip, hope you have a decent trans! :D
Also very curious to know what the spool is like! Looks like it would be an absolute weapon, good job!
What turbine housing size - also single/split pulse + gate setup?
Perhaps drop something into the RB25 dyno results page
Strong result.
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
