Hi Nathan,
So do you rate it and would recommend it to others?   I'm only really looking to use it for fluid changes, brakes and tire changes etc, so pretty basic stuff.
Also which model do you have?
I've been looking at these also, the 5000 model which is enough to lift both my cars (GTR and Silvia).
However, for similar money you can get mid lift scissor lift that will go 1-1.5m, the issue being ground clearance for low cars and not being as portable.
If there is any way to use  I hoist I'd go that way in an instant.  Quicklift is a lot of money for a quicker version of jack+stands. You'd need to be lifting a lot of cars to make it worthwhile I think
2 post hoists start at about 1500 for a second handy that would be fine for weekend use.
8 hours ago, BlueThirtyFour said:
Hi Nathan,
It serves it purpose for me. If I could have a 2 post hoist I would of. Much quicker and easier than jack stands.
I've only used it to change fluids and service my breaks so far, but prefer it to jack stands as it is more stable. Last time I used jacks stands was a few months ago when pulling the motor out of my brothers car. Getting it up onto them was a pain in the ass and that sold me on getting the Quickjack. You could get more height if you got the light truck adapter kit, but I think it is high enough for most things including pulling the gearbox out.
ive got a maxjax like below - full height with the bonnet up on the 33 is 2400
cant walk under it, but a stool with wheels is easy enough, 240v and uses threaded anchors not dynabolts to make it portable to some degree. atleast pack it away when not in use
  • Like 2
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
