Cheers Tim hopefully ill never need it!
Yep bracket is for mounting a trip computer - will need to build another bracket off it once I settle on a unit. May end up with a camera attached there as well.
The drivers seat bracket is set up for an aftermarket rail kit meridian have supplied. Bit worried about it actually itching to get a seat in and test with my helmet on make sure I have enough room. I am 6'2 but my girlfriend will be doing some driving as well hence the rails - she is 5'4 and struggled for height driving the car with the standard seat.
Worse comes to worst ill just loose the rails so only I can drive the car :P
ahh I've got the same challenge with my seat. the bride rails are about as low as you can get, but the cross in the cage on the roof will impact helmet room. I had to stick with only 1 diagonal on the roof for that reason
  • 4 weeks later...
Did a test fit up of the drivers seat with the mounting bracket and my helmet on.
Bad news is the mounting bracket isn't quite right - just a tad off center with the steering wheel to the window side. Meridian are going to make a few tweaks to get it sitting where I want it, and by raising the front a little will give my girlfriend a bit of extra height when the seat is slid forward.
Good news is I fit! The double diagonal cross in the roof is well out of the way my head sits up in the void perfectly. With the seat a little off center I am very close to the other bar but once the new bracket is in it will be spot on.
Old motor big end bearings from cyl 6 on left, good cyl 5 on right. Had been driving on these for a good six months... somehow they didn't spin. Chris reckons the old crank should be ok - barely any scoring on the cyl 6 journal. Thinking I might send the old crank and block off to get cleaned up and machined and have a go at putting a basic motor together for shits and giggles.
New motor is almost ready to go.
  • 3 weeks later...
Mick found this little surprise on the rear drivers quarter under the sideskirt.
Previous repair from its life back in Japan was a little shonky wasn't really sealed up properly there is rust pretty much all over it. Not worth repairing so a new quarter has been ordered from nissan.
Otherwise not much. Have ordered a new brake booster & master cyl, cluctch master cyl and a few other bits that are past it.
bummer i would have just repaired it cheaper than a qtr pnl I would think. good luck man!
Would love to have but the same panel is rusted through at the seam around the boot jamb, rear windscreen, drivers door jamb and the wheel well - this was the last straw!
There are also a few other spots that are starting to show a little but we won't be able to see the extent until it comes off.
  • 3 months later...
Awesome build man love that cage! I've got a 32GTR build on the go at the moment too but nowhere near as nice as this! I really should get off my bum and start a buildup thread but im waiting to have a new shed built soI haven't done much to it lately. Oh well these things take time. Your right though i live in Tas and there are some truly inspiring roads over here. Keep the updates coming especially the Paint Job. ;)
  • 1 month later...
Shell is up on the rotisserie now. Not the prettiest thing from underneath at the moment.
post-12551-0-18579000-1303170240_thumb.jpg post-12551-0-33256900-1303170245_thumb.jpg
Also gut stuck into cleaning the front subframe. Before shot only but needless to say it is now looking a lot nicer.
Picked up some Racepace modified Tein RA's
Midori 76mm dumps and 76mm into 90mm front pipes. Will get Racepace to sort out the rest of the exhaust.
post-12551-0-06889300-1303170907_thumb.jpg post-12551-0-27864900-1303170916_thumb.jpg post-12551-0-75263400-1303170946_thumb.jpg post-12551-0-45707000-1303170958_thumb.jpg
  • 4 weeks later...
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
