fatz at oktoberfest.............that will be special.
ill be in gemany in october hitting the cans next year
happy to back it into a wall for ya, some people say i f**k around..,. but i garrentee to do it propoerly!
What are you doing with the Plazaman plenum?
Would love to see if it makes a difference in low/mid response compared to my plenum, I dare say it will, but I'd love to know before I go changing the intake again...
No thanks...woudl rather continue to nurse my little bus along and maintain my record of not being a car breaker....just crasher :laugh:
If you don't:
Throw a leg out of bed.
Spin a bearing.
Smash a Gearbox
Leave a diff on the ground
Or Eject the axles from a car,
You're just not trying hard enough!
Well, just need ome velcro for Blitz gear and centre console is finished. Next weekend will be making a better means of mounting the data logger on the column....never liked my old bracket.
I am waiting for my injectors and thephenolic gasket to arrive before I throw the Plazmaman on. I may be doing it next weekend whcih will save me a quid rather then the mechanic doing it :laugh:
I think i bought it off ebay or online somewhere...cant remember. It has been laying around for along while until i got a harness to move the aircon controls
Wait, so where did the air con controls go?
Interesting... Very interesting...
I need to redo my centre console, and that looks f**kING ACE!
sorry to hijack Roy.
i can suply you with a pic of carbon sheet to do the job.
i made and installed a similar pice in bens gtst http://www.skylinesaustralia.com/forums/Be...html&st=380
So some more pics I took whilst working on the girl...So current work in progress
TE37s before stripping, 17 x 9.5" rears and 17 x 9" fronts. Were in white. I actually really liked them in white but loved my old satin black LMGT4s so...
Before
After stripping
Awaiting custome decal set
They were abolute pricks to rub back and prep, even after getting them acid dipped. Big thanks to Troy for doing a top job on the colour, satin black with grey pearl with matt clear...looks mega cool in person with the light on them. Shame once they are on the car brake dust will most likely hide their real colour
RB24 Gear
Well, been hoarding this gear for a while now, but have to either build the engine in the next few weeks, or sell it. Imminent work OS means tough decision needs to be made. Dotn want to really build a motor when the std one keeps on rocking....
And with the Tomei solid lifters and 260/10.25mm Procams I needed to upgrade the valve springs...so knowing nothing about engine building it was time for some more catalogue shopping...
And there is always those annoying jobs you wish you never started. After my fire at Winton all those years ago the wiring for my AiM data logger was damaged. It required a new MAP sensor, oil temp and pressure sensors and wiring....so rather then just simply install what was required i ripped it all out and decided second time round I could do a better job of wiring it in....and has since sat in its box with the new sensors and bits
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
