Ok, so the quest continues.
Bought a new turbo this week. So the plan is the 10cm housing goes on next week. Thinking is that the plenum seems to have lost a little in the middle but seems to be a bit happier up top. But just wont make any more power so guessing its the lil 8cm housing. Will see what the 10cm housing does...
So along with that I am taking off the ARC 100mm thick cooler and installing an R34 GTR cooler. Hopefully being a bit smaller in volume we may get a bit of punch. I am a sceptic so will be interesting to see the result of that back to back. When the RB24 goes back in I may throw the ARC cooler back in, but perhaps 100mm cooler is simply too much core for a lil 2L.
So, after the cooler nad 10cm housing and tune it will be decision time. If the 8cm housing looks to have bene the culprit for holding back the bolt ons the cams will go in....but meanwhile. The kinder surprise bitsa motor will have the following turbo setups to trial:
- TD06-20G with 8cm and 10cm housing
- T67-25G with 8cm and 10cm housing
- TD06-25G with 10cm housing
and if i can get a minute with working this weekend will try to fit the Stoptechs this weekend
So, as you can see it kills response but does help flow at the very top end. But the combination of the plenum and other recent changes now means I have lost about 30rwkws through the mid range :( :( :( :( :(
Will see how we go with a few more trials and erros, may as well throw the 10cm housing on it now and see if we can break 295rwkws...fark knows it needs way more top end now it has lost the response that made it pretty damn quick for a 2L
As you can see at 116km/h i used to have 20psi and 185rwkws. Long live std cams, plenum and a full Greddy setup rather then 6boost and Turbosmart mani-gate setup :(
But even then tyres are all different sizes so cheat the truth a little. Road speed is road speed is road speed. At the end of the day you go through corners at a certain speed not rpm...so understanding what the car is doing at that road speed makes it easy to work back from (IMO)
Sav, real interested to see how you go with your plenum...before tuning your car I would be going back to the std plenum if i were you. No way an RB26 throttle body with its bigger bore etc is going to be a good thing on an RB20 (pure speculation but just a feeling i have) And since you are racing your bus...throw the 26 throttle bodies in the bin. Ideally grab something with a smaller diameter and use the phenolic gasket etc to try and get some runner length back
i've been quite surprised with the car. Damo's done more driving than me cause i've been tuning it, but i've found it nice and responsive when i have driven it. Throttle response is much better than std. All in all i'm pretty happy with how mine feels, esp since it's running flat 15deg timing and 10psi of boost.
troy.
sell plazmadude plenum. refit old standard plenum with nice piping you had (i always liked it)
buy or refit trust mani and trust gate (we both know they are both good bits of gear)
enjoy.
I agree the 100mm ARC core is too big. go to 70mm ARC core. they are same size as stock GTR core, are LIGHTER than a stock GTR core, flow more, cool more and also allow more air through to the radiator due to better design. that's what you want.
then you will be on the path to greatness.
oh, and agree with troy road speed is the way to go for the bottom axis on the dyno. also much easier to compare and does not allow people to 'lie' by doing runs in 3rd gear etc as it instantly shows up with the speed. :)
oh see i was always of the impression that the dyno picked up engine RPM by one of the probes as you can pick up RPM from just clamping onto the battery for example.
so i would have thought that comparing engine parameters like spool time ect would be better done back to back with true engine rpm as like a KW reading there is several factors that play a part. just strapping a car down tighter can change a reading.
i can easily see where road speed can be used but if your trying to compare apples with apples shouldnt the most constant of all variables be used?
theory and reality dont always go hand in hand. we have a dyno proven 295rwkw stock internal rb20 with a rx6 turbo on a stock exhaust manifold running at the circuit. most people would say thats not possible. mainly the stock manifold bit.
the thing is at the end of the day were happy to trial somthing different just the same as you are but we havent had the luxuary to trial it back to back. we will more so just look for the small details and compare it to similar modded rb20s we're involved with. if it has such dier results im sure they will pop up. while we both love to jaw off about how cool it is, we arent going to market them to the world so we dont need a fancey dyno proven figure to tell people what they will do. i initaly did mine as a cost cutting exercise as a plazman was to expencive for what it was. a custom made welded thing would have cost similar due to paying a profesional to weld it all up and the setup i have ment i made 95% of it at home so the cost was only in the odd bits i needed.
Yeh, but arent you running an RB25? The aerodynamics of the RB26 plenum on an RB25 are going to be simimlar. The gas velocity and cylinder filling etc on an RB20 will be different. Not saying different is bad, different could be better then std.
Hear what you are saying about not needing dyno figure, but its handy to see the characteristics of performance changes. Driving the car didnt really feel tht different, but dyno suggests there is a fair bit...i wont know until i drive the thing in anger and in whch case any loss in response will be very noticable
is't the plazman plenum just a replacement for the top 1/2 of the rb20 inlet? IE it keeps the std runners.
The local guy here with the 295rwkw made his own plenum using the same idea as the plazman, and he can't praise it enough.
Spose the question is, do the dyno figures always match the real world? As you said you probably won't know till you go the the track and see if loss of response on the dyno equates to anything.
Yeh, it bolts to the top half of the plenum. To drive it doesnt feel voerly different. Unfortunately I dont have the logger installed so couldnt really compare 2nd, 3rd and 4th gear acceleration plots to see where the truth lay...dyno , seat of pants or somewhere in between.
I have tried to control the before and after as much as possible, same boost controller, boost, tuner, dyno etc etc. So all I can talk to are my experiences but as a result i probably will question the results of others just to understand why I am in the position I am in.
Re dyno figures and real world results...i suppose often there are stories where dyno improvements are not translated to real world gains. I am not sure there are too many stories of dyno showing losses but you have improvements?!?!?! The throttle response is no better or worse really so ... time will tell...some more things to try over the coming weeks
So the tune has been tweaked with the new inlet manifold on and the results are not that encouraging :( This weekend I will work on the cooler pipes some more, check a few more things and see if there is anything to be gained. Then will replace the big 100mm ARC cooler with the std R34 cooler I have got in the boot and then its just a matter of throwing my Momo seat that I got out of storage back in, bed the new brakes and hopefully be able to start enjoying it again.
Still got to put the new radiator, thermo fans, low temp thermostat and new hoses in too....but thats all stuff for a lazy weekend
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
