  • Replies 270
If it is anything like the beastly unit he made for me or the even larger (!!!!) dump pipe he put on his own M35, you will certainly notice quite a difference :)
hehe hope thats the one i got .. because mine is large and spiffy heatwrapped ^ :D
big :( scott.
btw scott.. hows our dolphin replacements going for that turbo inlet.. tell your wife we need you on the mig! :)
Edited by PetroDola
Dolphin? bah!
My intake craps all over that one. :P
I can make it whenever you want buddy...
awesome - champ!
from what i understand also.. the dolphin upgrade isnt mission critical its the other piece you've welded up, although i understand the dolphin helps marginally with the flow rate.
im looking at rebuilding this turbo to be ready by late dec/early jan depending on how long they take.
so anytime around then would be awesome?
and what do you want for one?
Cheers
Keir :D
Edited by PetroDola
Angus,
Put me down for one mate. My preference is to have it looking factory stock for the ceramic coat..
To all the others who fitted theirs by themselves:
Oh and I don't have a hoist, but it sounds like dropping the gearbox X-member is the way to go.
Can someone detail the steps to go through?
Dropping the gearbox x-member is not required.... even without a hoist.
Just get it up on ramps/secure axle stands, undo the front pipe at the dump (2 bolts) and f**k around for sometime trying to get all 5 bolts/studs undone so you can remove the dump.
Some swearing is recommended for release of frustration :whistling:
Oh, and make sure you do it when the dump pipe is cold!
Lastly, WD40 is your friend
Edited by iamhe77
Bends have been bought! flanges are being cut! we're moving along in the right direction!
What kind of coatings do we want? the dark coloured stuff or the polished look?
Champion effort!
By coatings, are you still talking ceramic?
I don't know about anyone else, but I'm not expecting enter a car show so the only way anyone (other than my mechanic?) is going to see the pretty "polished look" dump pipe is if I roll the car in a ditch and it's upside down.
So I'm not overly concerned, except darker sounds like it's less likely to show up my grubby fingerprints, and those blood stains from my knuckles from trying to fit it..
Some swearing is recommended for release of frustration :(
I made my own Stainless dump pipe for my 1600 and getting the F&*(^King 02 sensor off while in the car was made extremely easy by dropping many F bombs... Don't worry I'm fluent..
Sounds like a good job..
Might take some photos and add to a build thread on here?
Yeah no problem, the coating is the ceramic, Andy said there were some heat issues with the last ones, passenger feet getting a little warm so its a move in the right direction.
Sounds like Black coating it will be!
Not looking forward to finally fitting my one once they are done either! it sounds like your typical nissan dump pipe.. dont plenty of gtr ones and they are so annoying.
Anyone know if this sale item is a replacement of the standard dump pipe and part of the standard front pipe that attaches to it?
http://www.importmonster.com.au/view?url=h...0NM35%20VQ25DET
It looks like it could be.
The problem that I can see here is, pipe dia. off the dump is 2.5" so you're not getting the best possible flow, and you will also need to cut it and fit a cat about halfway along that pipe if you don't want to get a fine.
Add to that, I would recommend a flex bellows off the flange before the bend. By the time you have this delivered to Aus, modify it to suit, you would've been able to have a custom pipe made EXACTLY how you want for the same dollars.
Edited by Daleo
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
