Yea the old wire 53,,,not cut mate,,,so I'm at a loss as to why I can get away with over 180 and there is no sign of mods. Figure that one out.
Okay thats interesting as our car can alternate between low and high beam but never both on at the same time. I'm sort of hoping that we can run the low beam on and flash slower cars with the high beam.
Duncan and I would both love that little feature.
Cheers
Neil.
this can be fixed with some soldering skills.
if you pull the stalk off the column there are two gaps you need to bridge with solder.
i can get you some pictures as i need to pull mine off.
Oh I have the soldering skills,,,and Duncan has them as well. Here's some pics of my stalk,,,
Do tell mate.
Oh and check out the Veuve in the background,,,nicely donated by Mrs Handley,,,the girl is all class.
Cheers
Neil.
damn straight 33 has a speed limiter....I spent literally hours a day on it when I lived in the NT....192 = game over. no sign of mods on Neil's car but something was done.
the loom neil mentioned had a heap of functions and non-nissan parts, so I bet my left one it was done by the compliers. It included dash dimmer, new headlight resisters and relays and side indicator repeaters....as long as some other stuff I missed. Maybe it was the speed cut as well (I'll lol if Neil comes back from the first session swearing about a speed limiter!).
All gone now, as is the alarm, cruise control, airbag etc. some quiet day we will remove the wires not required from the dash and body looms too
Do tell mate.
Cheers
Neil.
On the back of the indicator/headlight stalk you will see two bridge points (circled in red) these need to be filled with solder as seen in my picture. this enables the low beam to stay on as the high beam is switched on, it also leaves the low/high beam lights on their own seperate fuses and relays so you dont run into other electrical issues.
This is the other side of the stalk if you want to pry it appart, the hardest part of doing this is cleaning away the lubricant and getting the solder to stick.
Thanks heaps mate for the pics and explanation,,,will come in very handy,,,but for the life of me I still can't work out why someone went to so much trouble.
Heres pics of what Duncan removed.
Cheers
Neil.
Well that was a hot hard working day,,,gotta say I'm not a 7.30am Saturday guy,,,I usually have a late Friday night and sleep in till at least 10,,,not today,,,had to clean all the stuff around the car so we could work,,,buy some gloves and dry ice. All went well till the guy tried to give me 3 x 5 kilo blocks,,,no,,,no,,,no tiger we ordered pellets,,,oh theses are great just sit them on top and they will work perfectly. Kiss my arse pal,,,in the end we got 20 kilo's of pellets for I think $140 bucks,,,.15 kilo's would have been just enough but I've been down this road before and having some extra to clean up the harder bits is a god send. Duncan turned up at 10.30 but I being the in-patient prick I am I had already started. Sorry for no real before and after pics but it was bloody hot and I needed to get as much insulation out of the car as quickly as possible. If you ever do this please buy the dry ice,,,using a heat gun and scrapper is a 3 weekend bastard of a job. Been there do that. After removing almost all of the deadening it's onto using a wire wheel and I still have some work to do,,,mainly cleaning up and removing lots of seam sealer. These R33's are a luxury coupe boat for a reason,,,heaps of insulation AND it's thick,,,some places it's 4mm thick and some of the stuff Nissan use the dry ice doesn't do a thing.
Heres some pics I did take though
Boot area,,,didn't vacuum it afterwards,,, but it's sweet.
Local boot area clean up shows just how cold this stuff is
Here we have my fellow Team Raceworx driver/pit crew/track bitch Duncan,,,hard at work,,,check out the work ethic,,,the mans into it.
This is basically what we ended up with,,,pretty bloody cool in my opinion.
As usual,,,Mel looked after us,,,Hamburgers and chips for lunch,,,I love my Wifey.
How much weight did 2 guy's remove in 6 hours of hard bloody work you ask and let me tell you theres about 1/2 a kilo still on the floor.
That enough for now,,,Handles is by now drinking wine and I'm going to smash some beers fatz style.
Cheers
Neil.
Looks very familiar I remember that bit o too well. Knowing how much there is in the r33 you guys have done well, I used either tirps or metho I can't remember with a rag to clean up the scumy bits.
Keep up the good work.
I did the GTiR with a hammer and chisel, took half a day but being an RB model it had bugger all of the shit!
I got another GTR you can strip out Neil.
Will you be ready for Thursday still? I have a new brobo cold cutting saw and a real nice linisher in trying to find time to use!
Edited by Risking
2012 is the plan mate. What worries me is rule changes,,,so my thinking is to get it done sooner than later.
All the air con will be gone before Brad gets in there with his tubes and welder but I will be leaving the heater in it. After last weekend with Duncan at E/C and Mark last year at TT theres no way you can not run something. Snowman has a heated front screen,,,while that would be nice,,,try finding one for an R33.
Cheers
Neil.
if you are interested neil I have a mate getting a batch of about 50 heated fronts screens make up in the UK. can do any car they have a pattern for and I'm pretty sure R33 is on there. about $500. it's also lighter than stock and is DOT/E marked therefore road legal and means no more heater needed.
"Looks very familiar I remember that bit o too well. Knowing how much there is in the r33 you guys have done well, I used either tirps or metho I can't remember with a rag to clean up the scumy bits."
Ryan,,,yea that was funny,,,heaps more in a 33,,,wonder whats in a 34. I started using brake cleaner and thinners but Duncan was getting off on it so I had to stop.
"today was an absolute flamin mongrel of a day. we removed 1kg/hr each. better be f**king worth it"
Get over it bitch,,,you loved every moment,,,and yes you were right,,,my body is still hurting. Worth it,,,deep down you love RWD's.
"lol any dry ice burns on your arse those hurt 3 days later"
No burny bums Pete,,,you are not actually surposed to sit on it you know.
"Now you just need to paint it all in there to make it look nice and pretty!"
Yes Matt trust me it will be beautiful. White,,,White and All White,,,KH6 from memory. Can't do much till Brad finishes his handy work.
"I did the GTiR with a hammer and chisel, took half a day but being an RB model it had bugger all of the shit!
Will you be ready for Thursday still? I have a new brobo cold cutting saw and a real nice linisher in trying to find time to use!".
Brad ,,,you animal,,,a hammer and chisel,,,half a day hey,,,Cheryl will beat your lack of 2 cylinder pulsar in the looks dept. Yes Duncan and I can do your GTR,,,but you may not like the price buddy we don't come cheap,,,lets see 12 hours x $120 bucks an hour works out to be $1440. I'll ring you tomorrow about thursday.
"if you are interested neil I have a mate getting a batch of about 50 heated fronts screens make up in the UK. can do any car they have a pattern for and I'm pretty sure R33 is on there. about $500. it's also lighter than stock and is DOT/E marked therefore road legal and means no more heater needed".
Richard YES I am very interested,,,In fact I'll put my hand up for 1 x r33 and 2 x R32's. Do you have an idea of when they would be available?.
Cheers
Neil.
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
