Brad,,,do the peterson tanks seperate in the middle like these???.
http://www.larnerengines.com.au/Details.asp?ProductID=86
Remember I'm only researching at the moment guys,,,but it has to happen sooner or later.
Ryan,,,No to the pedal box mate,,,no need for that stuff till I have decided the factory brakes are past their use by date.
I'm not allowed to have the cage entering the under-bonnet area. Brad had a top idea though of running tubes out through the skirt area and welded to the inner of the strut tower which would make it legal,,,but quite frankly where do you start and stop.
I could turn this car into a marathon build if I'm not careful,,,Duncan,,,Kelly and I want to drive Cheryl early next year.
Cheers
Neil.
Yep Peterson tanks have all the good bits, 3 segments inside the top entry and spiral plates, a middle section with mor spirals and baffles then the bottom section which ita drawn from.
I've had a tank spun up preveiously and replicated the Peterson baffle/ divider but the ammount of stuffing around and spinning cost it is easier to buy one!
The inner turret idea has been done before to a few prod cars doing the rounds. And a few other category cars which don't allow fire wall bars. It's pretty nessisary on any circuit serious nissan, the front ends suck badly.
I do have an over hung tilton box you could utilise Neil ;)
you just need to keep the pivot points of the pedals within 75mm of original if my memory serves me right?
Well I hope everyone had a great christmas.
Boxing day's work started at about 11pm,,,Duncan started helping me remove the rear suspension so I could change all the rear arms to the nismo ones. Smart boy stopped that painful job and left me to snap the ball joints ect,,,which was cool,,,no point both us yelling,,,swearing and cursing.
He started removing all the rubbish wiring from the rear harness,,,must say I was very nervous seeing all those bloody wires being removed. I beleive he removed all the hycas and stereo wiring,,,nice work tiger. I always love the lines we use when working on each others car,,,"Not my car mate" and "I need a Glory job mate".
He came back in the late arvo to install the hicas removal bar,,,It's quite frightening how much movement there is in the bushings without the rack fitted,,,even with nismo bushes. If the car wasn't being setup to Targa spec I would look into changing everything to eliminate the bar completely.
We had a very brief look at how to install a rear tow hook,,,no way am I cutting the rear bar and Nissan's factory hook is not low enough to actually pull Cheryl out of even a sand trap without ripping the bar off. On closer inspection I realised the factory one is un-boltable so I've come up with this plan. Little bit of weld love and it will be done.
Two pair of these turned up today out of HKS USA. They are rear upper mounts but with some stud changes one pair will be used on the front. Funny though the nuts are different threads,,,you would have thought the Japs and the Germans would use the same. No biggy just more work. What's even funnier was the delivered price,,,John at UAS has A pair that he's had for years and I offered him 260 buck but no he wanted 400,,,. Sucked in Johnny I bought 2 pair for less than what I offered you.
Unfortunately for me we have a GTR to put back together so Monday and Tuesday were spent doing that. Not complaining,,,I was booked ages ago.
Cheers and have a HAPPY new year.
Neil.
its moveable now.
and neil you have a gtr to put together next sat/su/mon as well :P
were those HKS strut tops dusty?
Yes Duncan you are correct,,,Brad it is movable right now. No way am I installing my shocks while you have her,,,you might steal my spring rates. :whistling:
Sat/Sun and Monday,,,put the ice pipe down mate,,,3 days = NOT.
Funny you ask about the dust,,,I received 1 x old stock (same as Johnny) and 1 x new stock,,,both all sealed,,,nice and new.
Cheers
Neil.
Spring rates! Meh just run 12/10 that should be great according to the monkeys around the place who know everything!
I could sell the info to the interested people though ;)
not that it's really that hard to work out what works anyways.
Possibly sooner,
I have an r31 which is causing me all sorts of grief currently, nothing simple and is consuming more hours than I care to add up!
I'll have a good idea by Friday if I can take it earlier.
Yep keep me posted Brad,,,it's all good,,,oh by the way Cheryl is not an "IT",,,she has feelings. R31's are IT'S.
Cheers
Neil.
only just got round to reading this. Have you been keeping up to date with the Targa rules? us double wishbone people are now 'officialy' allowed to run adjustible upper arms . Why arn't you running a GT-R body kit? It's a cheap light weight bonnet.
What weight are you aiming for?
Ben,,,great to see your reading all this!!!. I've read all of yours.
I'm going off THC rules at the moment,,,please point me to newer ones if you can. Adjustable upper arms sounds great. Duncan said exactly the same thing about the gtr body work,,,while you both are correct,,,I like my front end just way it is.
Weight,,,thats always interesting,,,I beleive offical weight is 1390,,,mine when complied was 1370. If I can keep her under 1400 that would be great. It's funny we rip all the crap out of these cars and then start adding it all back.
Cheers
Neil.
That weight of 1370 kg is very close to the mark as I had to get a weighbridge ticket for my R33 for the blue slip to get her registered and she came in at 1372 kg in stock road trim.
Now that she is registered again my worry is that after the Brembo's, new intercooler, big exhaust, big radiator, GTR rear end, GTR body braces etc etc go in I will be up around 1400kg before Brad starts on the bolt in cage.
I'd expect it to go under 1400kg easily.
Has anyone actually weighed a properly built race GTs-t?
Know exactly what a GTR should weigh in at but I'd think 1400kg is too much.
The cage Neil has in mind shits all over 90% of the cages doing the rounds but will Be somewhere between 45-65kg
a typicalbolt in job is roughly 12-18kg and a weld in full cage 30-55kg typically in CDS.
I rekon a GTS-t could get down to 1200kg if not less with the right parts.
A local track R32 is down to 1190kg, that's with an extensive cage. It's stripped as light as you can go with Targa regs, but it's still got a gtst bonnet. So 1176 with gtr bonnet?
I'd guess 1280 would be about it on a R33, with it's gearbox, and extra body bracing. If we could run carbon doors it'd make a huge difference.
Woosters R32 was about 1240kg, and i'm aiming for under 1200kg with mine. Alot easier to do with a flimsy R32 and little gearbox.
a 12l dry sump would be heavier than a wet sump.
Are you guys removing all the factory side intrusion from the doors or leaving it in??
I know we took 38kg out of my old GTR by cutting that out of the doors.
You will add about 40kg with a complete dry sump, pump, and oil are the heavy parts. alloy tanks are light and if you use prolite hose there is bugger all weight added there.
It lightens your wallet too if you use prolite hose!
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
