I was trying very hard to keep my stuff-up a secret,,,like very in house,,, but seems thats dreaming.
Basically I stuffed up,,,went in to quickly and she woudn't turn, i was trying to catch a v6 supercharged commodore in my class and f**ked up.
Yes I have pics and vids,,,just no time for that malarcky,,, i have spend the last 2 weeks stripping her and putting her back together,,,12.30 nights every night, I'm rooted to say the least.
Cheryl Lives on,,,thanks to all the help from the following great people,,,in no particular order,,,i love you all
Pete and Jenna,,,thanks for all the parts,,,what would I have ever done without your help guys. THANK YOU
Duncan and Matty for all the helping put her back together,,,thanks both of you for all your time and effort,,,very much appreciated.
Mathew at Race Brakes Sydney for helping me out with new Discs and Pads,,thanks as always mate,.
So tomorrow a wheel alignment and get the front bar painted and she's good to go.
Cheers
Neil.
Seems some one was videoing Cheryl as well. At least she sounds great.
https://www.youtube.com/watch?v=m77HeRx7_t4
If the wheel alignment comes back bad and I can't take her to the SAU nats,,,I have a backup plan. I've been offered a drive of a very modified clubman.
Cheers
Neil.
I've been into (or up actually) that bank as well mate. Probably 10 yrs or more ago.
Mt Cotton is a difficult place to come to and try to go real hard first time you've ever been there. It caught out alot of very experienced hillclimbers that weekend, so you're in good company.
Good to hear it's pretty much ready to go again :)
Yep on the money there Harry,,very technical track to get used to,,,I'm usually pretty good at working out where I can go quicker and I had lots of help from an old mate from up there. Seems I picked the wrong spot to go in deeper. Bit shocked at the carnage that happened,,,lots of open wheelers crashed which is very unusual.
Ben there were a number of times going down the 1st loop that I and many others had the old shvinkter tightening up.
Time to start packing for Adelaide,,,wheel alignment is great.
Heres my in car,,,everyone loves a stack.
https://www.youtube.com/watch?v=FCmfgWy5sQA&feature=youtu.be
Cheers
Neil.
  • 3 months later...
  • 4 weeks later...
actually it drives beautifully and very predictably, and has done more motorsport in the last 3 years than any other SAU car I can think of. I'd have it in a second over most cars around the forums.
  • 1 month later...
Cheryl had a date with Yavus of Unigroup Engineering fame on Saturday and I believe she has fallen head over heals in love with him. After playing with her bits,,,I approved of cause and she now has 242kw's coming out of her rear end. I did ask if we could maybe lower her enthusiasm down a bit, but no was the answer.She does have a great rear end by the way.
That's using stock injectors,power fc, 040 pump, plasmaman inlet manifold,Z32 afm, FMIC and a Turbosmart boost controller.
We both left there very happy and I've entered her in next weekends VW Supersprint at Wakefield Park.
My only hope is I don't have to keep emptying her colostomy bag after every session.
Cheers
Neil
  • Like 2
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
