Bloody hell...what about yesterday,,,I think the 30/11/2014 will now be known as the day I actually started hating working on racecars.
After huntley hillclimb Cheryl went into the garage running as usual,,,beautifully. I had started making a front splitter for her and conned Duncan into using his hoist. Start her up and she's misfiring,,,pop the bonnet and could see nothing wrong and quite frankly paid it no real attention. 1/2 an hour later she's purring like a kitten again and onto the trailer. Get to Duncans and she's back to misfiring again. On to the hoist spent some hours finishing the splitter and now she won't even start. We checked everything,,,included removing all the intake pipes and hoses,,AFM,,,Coils,,,crank sensor,,,you name it we checked it. So in the end the only thing that had changed between huntley and now was I had put 20 litres of fuel in her,,,so we drained the tank and put 20 litres of fresh fuel in her,,,still nothing. By this time I getting very pissed off,,,Duncan's good in these situations and keeps a level head,,,me I could have started throwing spanners but hey they were his. So with all the cranking it was time to pull the spark plugs which were new and give them a clean,,,they were very wet. Wire brushed them and she started and ran as usual. Figger that out,,,we have fixed something,,,god only knows what,,,so time to go back onto the trailer and the bloody heavens open up. 9.00pm on a Sunday night 2 drowned rats later and well someones old tow car starts playing up,,,but thats another story.
Cheers
Neil.
Got asked this weekend, at Mt cotton if I was back for another go.... And to try and keep it out of the bank this time..... Didn't think to much about it. Till I Started reading this build. (think they where talking about your car)
Must be a skyline thing... I stuck mine into the nuts... :yes: Big car to get around that tight track...
Ha Ha that's very amusing,,,I would like to go back there for another go as it's much better than the goat track from this years Aussie hillclimb nats. I would have much rathered stick her into the nuts as well,,,much less damage. How cool are the macadamia shells for slowing a car down.
Cheers
Neil
  • Like 1
not as big as the Soarer that holds the record for the class :P hehe
Areo... that is just a black art I have never been able to fully get my head around. I like this, looking forward to your results young fella!
That looks seriously good Neil - what material is it made from?
Hey Dan,,,glad to see you are still lurking around SAU,,,. It's not really that hard,,,then again I sort out a person that actually knows aero and he basically told me "Flat Floor all the way to just in front of the rear diff and then add a diffuser for rear down force". Much like my Radical,,,so this is stage 1 or attempt 1. I will be making a full under floor system down the road,,,but I need to conn Duncan into using his hoist again. No way can you do it on stands.
Charles,,,
http://www.alusign.com.au/
It's just .3 aluminium top and bottom with a polyethylene sandwiched in between sign boarding. He usually only sells it in orders of 30 sheets but I told him a little lie and bought 1 sheet under the premise I would give him a big order next time. It works great on hillclimb open wheeler cars that don't use carbon fibre. It's so easy to cut,,,I used a jigsaw to cut the front and a sharp knife to do the rest.
Noddy,,, looks like you stopped at the rear of your front bar,,,not saying you are right or wrong,,,just wondering why,,,is it a rule thing maybe?.
Cheers
Neil.
I've been doing some aero development with John Campbell who has built a few successful 2A category cars over the years. If I ran a flat tray like yours and stopped it where mine has to, there is a large gap in the middle up to the sump pan. The Wheels create a lot of turbulence so isn't a problem there but to take full advantage of the stable air flow, it needs to be longer, like yours.
Mine dips up to some factory mounting positions for the original tray. It works very much like a diffuser does creating a vacuum at speed, sucking the front to the ground.
Yours relies on smooth clean air flow. It's maintaining an air cushion. It's like when you try and lift a sheet of core flute straight up off the bench. Air has to get in under it. On is own it doesn't create any down force, just helps to maintain the status-quo. The bigger the surface area this more efficient it is. The closer it is to the ground makes a big difference too.
buy that purple gtr and i might watch my mirrors
Whilst I like the car,,, the boss woman hates the purple,,,so short of a respray which isn't going to happen that car is out. I did say it would look great with bright coloured stickers,,,the answer was still a flat no.
I didn't get a lot of quality track time and I really needed to do some practice laps so I don't really know if the spitter worked or not. I only really got 4 laps in succession on my own and the rear end was a little more tail happy than usual. I had the Kumho V700's on her which I hadn't done any laps on before ,,,so I don't know whether I need more rear downforce or the tyres were too high in pressure. I might try a do another track day before the end of the year (Wakie Sunday 21st December) and try and get my head around whats what. I do know the my rear diffuser mounts are a massive pain in the arse to bolt up but I will fix that beforehand.
Cheers
Neil.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
