1 hour ago, mr skidz said:
I can post back another log when I'm on E85 if people want?
although some people get all sensitive and upset when I post actual data. emoji23.png
How about you post up your dyno sheet of your 5's and a built 2.8L and Brett can post his sheet of his 8374 on a stock 2.6L and everyone can see how the lil 2.6L belts you by over 100kw everywhere from 4000rpm to 8000rpm? Now thats ACTUAL data! ?
20 minutes ago, Lithium said:
I'm sure no one could flame you for that, any reason I can think of which would make you do that suggests things aren't going well for you :(
He hasn't installed it yet. Too busy trying to sell his -5's with the plethora of them for sale ATM. Haha.
How about you post up your dyno sheet of your 5's and a built 2.8L and Brett can post his sheet of his 8374 on a stock 2.6L and everyone can see how the lil 2.6L belts you by over 100kw everywhere from 4000rpm to 8000rpm? Now thats ACTUAL data! [emoji14]
Sweet if it looks as stock and clean as my engine Bay does using an r32 airbox and using 98 I'm in57ba35dc4e61c38980476bc78dd67236.jpg
should provide a log with:
  • MAP
  • RPM
  • TPS
  • Gear
  • VSS
  • Time
Then go for a drive shift 2nd to 3rd to 4th to 5th
Then we can analyse the RPM vs TPS vs MAP... what you will see is when TPS is 0%  and as TPS reaches 100% again in between gear changes that boost falls on it's arse and takes a few moments to come back on.
Actually looks cleaner to me.... Lets see how much of your "stock airbox" is left? Bet it looks like swiss cheese ?
Plus i bet his engine bay is alot cooler and easier to work on than yours ?
Pros and cons for everything i guess... Look stock go slow... Look modded go fast.... Its an individual preference and i respect that fact.
End of the Day you trying to make your car go fast? Im gunna bet the answer is yes.
Reality is regardless of what your engine bay looks like if the PO PO is gunna pull you over they aren't gunna start looking for mods. They will just send you over the pits and you will be screwed just like the other blokes with the faster "non stock" looking engine bays.
10 minutes ago, mr skidz said:
If you're boost still falls off that bad in between gears you need a new tuner..lol
Pretty happy with my tuna, I'm sure others are too.
12 minutes ago, mr skidz said:
Well DOSE if you're interested in drag racing data, Which I couldn't give two shits about emoji47.png
wouldn't you have the flat shift function enebled using a H pattern!!
Well Mr Skidz, I'm actually more interested in your transient response :)
I'm not a drag racing kind of guy either, not sure if you haven't noticed at all?
  • Like 1
8 minutes ago, r32-25t said:
I know of a guy that will buy them from you, damage them and then send them back for a refund
Owch man! Haha.
speaking of which arrived today. Let's see how I sent them.
Anyone can buy anything and then complain 4.5 months later that they're buggered. Without ANY evidence, PayPal rules in the buyers favour.
I WILL NEVER USE PAYPAL AGAIN!
Anyway, back to EFR's!
4 minutes ago, reaper said:
Sorry guys can't help you with any logs I got a bit carried away
Good news is the complete bolt on 8374 setup is now available so you too can enjoy :D
Is that your car now? You don't much around, mate!
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
