just washed mine after a run up the mountain on wednesday (was fithly after it)
got a hose onto it and gave the underside a good spray
i cant belive how much mud/dirt/rocks there were stuck under the side skirts and hiding away in the rear bumper
i reckon about 20kg of dirt came off the underside and i dont think it was all from that one trip
Well picked up my first stag yesterday 97 model and has 25t xfour written on the back got cream leather interior the satelite navigation tv screen in it has a full 3.5 inch TBE and hks turbo timer also has 18inch rims look like volks of some sort but gotta pull them off and have a look and the best part is I picked it up
for two grand with 8 month rego any how will be going in next week to have a new crossmember put in as the one in it is twisted and also will be getting a FMIC and injectors and eboost 2 put in and then have a tune done so will let you know how it all goes.
Patrick
nice 1.
finished with the stagea for now. last mod was the r32 gtr front calipers. 249rwkw.
working on doing up a r32 4door gtst sedan, with r30 manual & rb26dett engine.
excited. boat finally brought my container.
tomorrow get to p/up stich mags ($30 pound!).... these will hopefully fit the stagea
grex camshafts, spats strut bar, 6-point roll cage
exhaust temp sensor, turbo timer, bride left hand seat rail
bride drivers chair, apexi power intake piping kit
got all the parts for the rb26 buildup in the cupboard now:
hks oil pump, hks step 2 cam springs, n1 water pump, acl race bearings
hks 87mm pistons, attkd rods, arp bolts, arp main head studs
cometic street pro full gasket kit incl 87mm mls head gasket
tomei sump baffle pickup kit, tomei oil gallery orifice, ati harmonic balancer
greddy timing belt, new idler/tensioner, adjustable intake/exhaust cam pulleys
30-row engine oil cooler, oil filter relocation kit, turbo oil cooler
hks split dump pipes, obx tuned-length manifolds, obx front pipe system, decat flex pipe
fitted wilwood superlite forged 4-piston calipers with 324mm drilled rotors up front.
got to install the external fuel pump and fuel surge tank system, then attack the exhaust
and sort out the seats, weld in roll cage and add to it, fill the belt/seat mounts in (eventually rego for 2seater?)
I changed the timing belt and caused the check engine light to come on.... :D
^^^ oh........pull the globe it will be fine!!! lol
speaking of pulling globes... kidafa not that long ago changed his dash to blue LED's... and didnt put his petrol light globe in properly...
needless to say he got a rather decent mileage to that tank...:D:D
Yesterday:
Hacked up the CF-look centre console plastic to graft an R34 manual shift console onto. But 50% done. All cutting/trimming is done, now I just need to plastic weld it all together and bog up the gaps. Later it all gets covered with some real CF. :bunny: Should be finished by early June.
Touched up/puttied and resprayed my front Aero type M bar.
While I had the bar off, refitted the electric fan in front of the a/c condenser.
Had to remove the FMIC to refit the fan, so I also discovered a 10mm size hole in the intercooler, from a bolt on the chassis rubbing thru. :thumbsup: Fixed it up, refitted and test drove it after. Bit more responsive now :banana:
In the next fortnight, I'll be upgrading my brakes to a 325mm kit. :banana:
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
