Picked up the stag after new plenum install.
Sex!
Just ran a rag over it, so she's not detailed properly :)
Is that my throttle cable???????????????????
Why 66, yes it is! And its thanks to you I have the stag now :))
Incidently are the cam covers polished or chromed? My Gready look alike is chromed so i want the covers to look the same.
thanks mate, havent seen u for a while, and im on 2 weeks hols atm too so it will be a little while...though maybe not looking
forward to the roughness of annangrove road :)
Yeh it has been a while, Annangrove road is shocking at the moment i have been leaving the skyline at home most days and using the daily hack, hope they fix it soon.
badly when it rains down that road it looks like a mine field....
hi flow turbo and WB o2 sensor is in, max tp limit so no more fuel cut, pulled some fuel out, added a few degrees of timing and now its standing up when floored. Damn AFM is maxing out now though, will put my z32 one on tomorrow.
Also noticed when i took the standard turbo off that the impellor is all chipped, explains the noise when it was on full boost, (i was chasing a boost leak, it sounded like air squeeling). Looks like it wont be going back on the r32.
Whilst loading a case of beer into my garage beer fridge, accidentally dropped one on the floor. Bottle hits the ground, smashes, then to add insult to spilt beer, the broken end with the cap still attached, bounces 5 feet, hits the door of the Stag and put 3 little scratches on it!
F##k this for a game of soldiers, going to drink a few of his mates, that'll learn 'em...
found out why it whines on high boost :worship:
getting the turbo off was not the most enjoyable job tho
will fit the new gasket tmrw and bolt the 3inch dump up
also, lolz at the stock dump pipe, i'm surprised that the wastegate can even open
i also have a sneaking suspicion that the rest of my exhaust is 3.5 inch cos the front pipe on my car is a bit bigger that the 3 inch dump/front pipe i have and it necks down just before the dump->front flange
So after having my replacement engine in for a few weeks with a hi-flow on it, it is now back to a rebuilt std turbo, (my old one) with a ceramic impeller. The difference is HUGE. The hi-flow didn't come on until 3200 rpm. It was at max boost at about 3700rpm. The newly rebuilt std turbo is on boost even lower than it was before the engine was replaced. It starts coming on a 2200 rpm and pulls hard to about 6000. The car now has a Nistune and will be tuned before the weekend. The hi-flow was not for me, that's for sure. It was slower than my wife's Maxima, until it got to about 60kph, then it was doing over 100 kph before you knew it..... crazy as far as I am concerned.
I'll post up the dyno sheet after it is done.
Edited by Appealing
Replaced the plugs in my Stag and replaced the coilpacks too. Checked the CAS timing and reset the ECU while I was at it. :D
Also chasing why my brakes makes this loudish acoustics noise when its moving backwards (rolling back or reversing). Makes no noise moving forward. Got new pads and bedded them in on the track. They were fine up until I had to reverse out of my driveway for the first time with them. NOTHING is rubbing the rotors except the pads.
Mine does the same thing.
Jetwreck gave me his old r32 disks complaining bitterly about the squeal they had but I must have put them in backwards. ;)
Should have tried swapping them Craig...
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
