I think the fuel required to support 40psi is a little beyond a street car :D
You'd think so.......considering a top fueller runs around 50 psi....different animal altogether tho'
Edited by juggernaut1
snap.
50psi on an 8L motor with so much overlap the dynamic compression is basically nothing vs a 2.5/3L rb would be a different ball game. The top fuelers 50psi is probably 10x as much airflow haha.
snap.
Yes the comparison is absurd....around 400psi fuel pressure and around 4 litres of fuel a second consumption.
Nah. Going in next Monday for a few days. I've got a few other things I want sorted but I still needed to ask u a couple things. Do u mind if we have a really quick chat after 6pm tommorow? Or no good? Thanks heaps....
any updates?
I'd like to see a garden hose that can flow as much as that top fuel set-up! lol, more like a fire hose! even at idle it's crazy. no wonder they have 6ft flames out the headers....
wheres shifty ?
Here bro.miss me? Lol. Got car back tonight. They put a heavy duty 18psi actuator. Preloaded it etc etc. No difference. I don't think. Dyno shows no difference. In.fact less power at most of the revs. Maybe differ.ent ramp rates etc different temp day. Don't know. Not too happy
AVO or Status?
Ignore the dyno, of course it will be different, what matters is how does it drive?
Here bro.miss me? Lol. Got car back tonight. They put a heavy duty 18psi actuator. Preloaded it etc etc. No difference. I don't think. Dyno shows no difference. In.fact less power at most of the revs. Maybe different ramp rates etc different temp day. Don't know. Not too happy
yeah man, was wondering what happened to you..should have my car back soon we can go for a drive and see whos cars the slowest :rofl:
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
