To add to that, I'm warming to the GTX3584RS - it looks like the 1.22 housing is enough, and as I suggested the other day it looked like the 1.01 may not be too bad for what you're looking for either.  Looking forward to seeing results!
  • Like 1
Yep agree with you on all counts mate ?? Your calculations match what I come with each time I've run the numbers on the GTX3584RS and the others you listed.
Garrett actually quote between 9.5 & 10.5 hp per lbs/min. But I have wondered if that's a conservative estimate with the newer generation options.
It will be interesting to see how the 1.21 housing goes power vs response on a 3-4L six. Won't have to wait long as there's a couple of local 2JZ builds coming online reasonable soon.
In other news...
  • Like 1
Comp housing is about to head off for polishing (GARRETT logo will remain [but polished] as a feature) and the ex housing for ceramic coating.
I'm a little bit excited with my new toy ?
All three, at least in comparison to the Gen 1 GTX3582.
Blade pitch and profile has changed, especially the leading and trailing edge, and 9 blade vs 10 of the Gen 1 (correct me if I'm wrong) The blades are noticeably thinner at the blade root.
I'm far from an expert (my background is more jet engine based) but it appears the Garrett /Honeywell R&D focused on reducing mass to improve or maintain spool whilst altering the blade profile to achieve the claimed additional flow.
  • Like 1
Ha-ha. It was the best I could come up with at the time. The plug was sitting on the desk... I thought 'yeah most people have a rough idea of the size of a NGK plug box'.
A mate that is pretty handy at building modified turbocharged engines had a look at the turbine and noted they've reduced the material in the webbing between the blades and moved the bulk of the blade towards the centre in an effort to reduce rotational mass.
On ‎14‎/‎01‎/‎2017 at 8:38 PM, whatsisname said:
ETS hold the R35 drag ET world record (7.09 @ 209). Hopefully the GTX3584RS car runs some numbers at the drag strip to back up the dyno figure
That should read 7.01 @ 209
I'm so far relatively impressed with the Gen2 GTX3582R, met a lad with one on his fresh RB26 build at a track day I was at on Monday - running a 1.01a/r twin scroll T3 hotside on BP98.  I don't have much info on it, but I did see a dyno plot at the track and it was near 200kw by 4000rpm and made 460kw @ rear hubs (I'd call that around 410rwkw if you can't understand hub dynos) on 21psi.  It had a beautiful power curve for that level, with peak coming in at just after 7000rpm but holding >450kw all the way up to the 8000rpm they ran it to.
It seems like Garrett may have managed to go to a 66mm inducer without sacrificing too much in the way of response, and clearly have managed to do very good things for flow.  The car had quite a happy wee anti-surge whistle too, a bit less low-key than the Gen1 GTX - I have a soft spot for that noise so a good thing in my books haha.
Edited by Lithium
  • Like 1
Nice been eager on results.
200rwkw by 4,000rpm is unheard of in a 35xx turbo. normally ud see that in a gtx3071/3076
Pat aka Rekin should also have results from a Gen 2 GTX3071 internal gate on a Rb25neo in the coming months
Copy+Paste from my Build thread:
I am proud to share my latest purchase from GCG Turbochargers - A Garrett GTX3071r Gen2 T3 internal wastegate 0.82 low-mount RB setup.
With the GenII only released 3 months ago this is the first low-mount RB setup to pass through GCG Turbochargers & onto me :D
Big shout-out to GCG Turbochargers for responding to my endless FB messages after hours & helping me choose the right setup for my application.
Not only that, but the turn-around from Order to Dispatch was a matter of weeks when other distributors were quoting 3 month lead-times.
In addition,with GCG Turbochargers expertise in building turbos, they added a few extra tweaks to the build to aid boost control & overall flow.
GCG Turbochargers supplied in a RB25 low-mount kit; with all gaskets, bolts, studs, manifold spacer, braided lines, actuator, extra cheese - hold the mayo.
And to top it off, they been kind enough to send through some build photos :D
  • Like 2
+1, will be very interested to see how it performs in practice.  This is potentially a REALLY good choice for an RB25, especially if you have some other nice supporting tweaks to the car :)   What supporting mods, and fuel will it have?
+1, will be very interested to see how it performs in practice.  This is potentially a REALLY good choice for an RB25, especially if you have some other nice supporting tweaks to the car [emoji4]   What supporting mods, and fuel will it have?
Forged rebuilt Neo engine with an e85 setup - is the plan!
16 hours ago, MattSR said:
So, does anyone have any results from a single GT3584RS on an RB26 yet?
I wouldn't hold my breath, @whatsisname is one of only about 3/4 people I've seen any indication of using one for ANY car in the world right now and he has been really quiet so it's hard to know how long his build will be, this kind of thing often can take ages from the point the turbo arrives but will let him comment when he shows up :)
It's very early days from the turbo release and Borg Warner and Precision turbos are ultimately more known and desired in a lot of ways - and the Garrett is actually the more expensive option to a degree so they may not become very popular unless the results come out well.  I have to say, I'm pretty impressed by the Gen2 GTX3582R which has a 66/82 compressor instead of 67/84.... as it turns out @whatsisname's decision to take an early punt could pay off as on paper it looks like his setup could be one of the perfect matches to what it wants, so potentially could make for a very good result.
  • Like 1
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
