To add to that, I'm warming to the GTX3584RS - it looks like the 1.22 housing is enough, and as I suggested the other day it looked like the 1.01 may not be too bad for what you're looking for either.  Looking forward to seeing results!
  • Like 1
Yep agree with you on all counts mate ?? Your calculations match what I come with each time I've run the numbers on the GTX3584RS and the others you listed.
Garrett actually quote between 9.5 & 10.5 hp per lbs/min. But I have wondered if that's a conservative estimate with the newer generation options.
It will be interesting to see how the 1.21 housing goes power vs response on a 3-4L six. Won't have to wait long as there's a couple of local 2JZ builds coming online reasonable soon.
In other news...
  • Like 1
Comp housing is about to head off for polishing (GARRETT logo will remain [but polished] as a feature) and the ex housing for ceramic coating.
I'm a little bit excited with my new toy ?
All three, at least in comparison to the Gen 1 GTX3582.
Blade pitch and profile has changed, especially the leading and trailing edge, and 9 blade vs 10 of the Gen 1 (correct me if I'm wrong) The blades are noticeably thinner at the blade root.
I'm far from an expert (my background is more jet engine based) but it appears the Garrett /Honeywell R&D focused on reducing mass to improve or maintain spool whilst altering the blade profile to achieve the claimed additional flow.
  • Like 1
Ha-ha. It was the best I could come up with at the time. The plug was sitting on the desk... I thought 'yeah most people have a rough idea of the size of a NGK plug box'.
A mate that is pretty handy at building modified turbocharged engines had a look at the turbine and noted they've reduced the material in the webbing between the blades and moved the bulk of the blade towards the centre in an effort to reduce rotational mass.
On ‎14‎/‎01‎/‎2017 at 8:38 PM, whatsisname said:
ETS hold the R35 drag ET world record (7.09 @ 209). Hopefully the GTX3584RS car runs some numbers at the drag strip to back up the dyno figure
That should read 7.01 @ 209
I'm so far relatively impressed with the Gen2 GTX3582R, met a lad with one on his fresh RB26 build at a track day I was at on Monday - running a 1.01a/r twin scroll T3 hotside on BP98.  I don't have much info on it, but I did see a dyno plot at the track and it was near 200kw by 4000rpm and made 460kw @ rear hubs (I'd call that around 410rwkw if you can't understand hub dynos) on 21psi.  It had a beautiful power curve for that level, with peak coming in at just after 7000rpm but holding >450kw all the way up to the 8000rpm they ran it to.
It seems like Garrett may have managed to go to a 66mm inducer without sacrificing too much in the way of response, and clearly have managed to do very good things for flow.  The car had quite a happy wee anti-surge whistle too, a bit less low-key than the Gen1 GTX - I have a soft spot for that noise so a good thing in my books haha.
Edited by Lithium
  • Like 1
Nice been eager on results.
200rwkw by 4,000rpm is unheard of in a 35xx turbo. normally ud see that in a gtx3071/3076
Pat aka Rekin should also have results from a Gen 2 GTX3071 internal gate on a Rb25neo in the coming months
Copy+Paste from my Build thread:
I am proud to share my latest purchase from GCG Turbochargers - A Garrett GTX3071r Gen2 T3 internal wastegate 0.82 low-mount RB setup.
With the GenII only released 3 months ago this is the first low-mount RB setup to pass through GCG Turbochargers & onto me :D
Big shout-out to GCG Turbochargers for responding to my endless FB messages after hours & helping me choose the right setup for my application.
Not only that, but the turn-around from Order to Dispatch was a matter of weeks when other distributors were quoting 3 month lead-times.
In addition,with GCG Turbochargers expertise in building turbos, they added a few extra tweaks to the build to aid boost control & overall flow.
GCG Turbochargers supplied in a RB25 low-mount kit; with all gaskets, bolts, studs, manifold spacer, braided lines, actuator, extra cheese - hold the mayo.
And to top it off, they been kind enough to send through some build photos :D
  • Like 2
+1, will be very interested to see how it performs in practice.  This is potentially a REALLY good choice for an RB25, especially if you have some other nice supporting tweaks to the car :)   What supporting mods, and fuel will it have?
+1, will be very interested to see how it performs in practice.  This is potentially a REALLY good choice for an RB25, especially if you have some other nice supporting tweaks to the car [emoji4]   What supporting mods, and fuel will it have?
Forged rebuilt Neo engine with an e85 setup - is the plan!
16 hours ago, MattSR said:
So, does anyone have any results from a single GT3584RS on an RB26 yet?
I wouldn't hold my breath, @whatsisname is one of only about 3/4 people I've seen any indication of using one for ANY car in the world right now and he has been really quiet so it's hard to know how long his build will be, this kind of thing often can take ages from the point the turbo arrives but will let him comment when he shows up :)
It's very early days from the turbo release and Borg Warner and Precision turbos are ultimately more known and desired in a lot of ways - and the Garrett is actually the more expensive option to a degree so they may not become very popular unless the results come out well.  I have to say, I'm pretty impressed by the Gen2 GTX3582R which has a 66/82 compressor instead of 67/84.... as it turns out @whatsisname's decision to take an early punt could pay off as on paper it looks like his setup could be one of the perfect matches to what it wants, so potentially could make for a very good result.
  • Like 1
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
