wow, who would have thought this piece of shit track would bring back boring racing
How in the fcuk are places like this and hungary allowed to be apart of the calander
Well done to vettel, just counting down the weeks until this championship is done. Kind of a shame that with the points lead he has now, he doesnt even have to win or come second to have this all locked up.
Yep, I dozed in and out of sleep, f**king waste of race weekend innit.
+1 to this.
Oh, and am I the only one getting sick of hearing "I have no KERS, KERS is gone"... then said driver immediately puts in fastest lap of the race on their next lap or two?
Lastly, DRS is as shitful a Ecclestone... if DRS must be used, can we at least have it available on corners?
6L atmo? even that is waaaay too quick.
4 cylinder sounds crap, i'm suer v6 wouldn't be that good either. inline 6 is a possibility but for packaging reasons nobody uses them in production cars any more. v8 sounds crap especially with this blown diffuser nonsense.
I'm a fan of smaller capacity V10 or V12, NA. Keep the cylinder count high, no RPM limit, and reduce capacity as required to keep power within sensible limits. Besides that I say "anything goes" with the engine as long as they still sound meaty and not tinny like a motorbike. Not really a fan of turbo, it kills the exhaust sound. V12s were before my time but the V10s sounded magnificent.
Get rid of this reliability stuff, engines and gearboxes lasting half a season etc. The random blowups used to make things interesting.
Aero needs to be simplified still further, to make it easier for cars to follow closely. That and mechanical grip needs to be improved. I think DRS has too many rules, and is a bit artificial. I have no problem with KERS because drivers are free to use it at any point in the lap.
The main thing for me is the sound. In between F1 practice sessions when the two seater V10 comes out my jaw drops and I go what... is... THAT.... :worship:
When did this happen? Lap times drop with fuel loads but I think it is safe to say that KERS makes cars quicker.
as pointless as not even putting in a time in q3? these tyre regs need the most work
from start to finish, this whole weekend has been a complete let down
Refueling would solve so many problems. Two, three or four stints where cars are driving flat out rather than circulating to manage fuel, tyres, engines and gearboxes.
Button did it last night if I recall correctly.
Also I think Webber did it a couple of times earlier this year
Fuel reduction is the main reason plus the on/off nature of some KERS modules when they get too hot.
I agree, but JB did it the lap he was heard on the team radio last night.
Whether the team radio broadcast was quite delayed I do not know.
I think you will find that those messages are delayed, have heard the commentators say as much a few times, was more than likely coincidence
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
