Sorry if this bug has been posted already, I got to page 5 of the thread and ran out of patience checking.
The text in the posts come out in random sizes. Sometimes it is so small it is unreadable. Even with posts I have put up and I know I haven't changed the font size from default. It didn't do this in the old forum and has not done it in any other websites I have been to. It only seems to happen with the text in the actual posts not other text on the pages.
https://www.sau.com.au/forums/topic/346495-sau-30/page/14/#findComment-5595679
OK, I read the whole 14 bloody pages [well...skim read anyway] and:
I didn't see any mention of our SAU status, that is if you are a finanicial member of SAU Australia?
Also missing the Donation tag etc
Did I miss something?
https://www.sau.com.au/forums/topic/346495-sau-30/page/14/#findComment-5595878
it's just done it again! and i've noticed it's happened in other threads after you (LOACH) post.
maybe something in your sig is causing it.
https://www.sau.com.au/forums/topic/346495-sau-30/page/14/#findComment-5595891
Yeah they are still to be fixed properly... on the to do list
https://www.sau.com.au/forums/topic/346495-sau-30/page/14/#findComment-5595942
Munky was spot on, your sig was well and truly shagged, I dare say it didn't convert properly during the forum upgrade.
Fixed now though, well it's pretty close anyway!
http://www.skylinesaustralia.com/forums/topic/347707-20-inch-wheels-on-r33-work-meisters/page__pid__5593377
another broken sig. bold font this time
https://www.sau.com.au/forums/topic/346495-sau-30/page/14/#findComment-5596202
Hey, there seems to be something wrong with the trader feedback feature. I've tried everything but it still comes up with an error.
Please fix as I'd like to leave some positive trader ratings for some people that I've recently purchased off via SAU.
Cheers.
  • Nope 2
https://www.sau.com.au/forums/topic/346495-sau-30/page/14/#findComment-5596318
Woops, sorry guys. I didn't do any special editing when I created the sig just used the fonts given. Please let me know if you want me to change it (due to its buginess not its content :thumbsup: )
Thanks heaps for fixing it Revhead
https://www.sau.com.au/forums/topic/346495-sau-30/page/14/#findComment-5596860
sorry if already posted but are thread subscriptions working properly? I canceled all mine and redid them as delayed notification same setting as on all other boards and i am still getting a email everytime someone replies to a subscribed thread.
https://www.sau.com.au/forums/topic/346495-sau-30/page/14/#findComment-5598695
I hope so :)
Cos i've got a few trader ratings to leave/receive :)
Got it!
Stuffed up in my last post, you only copy everything after "topic/" not "forum/" (left a trader rating just then and it worked)
so in >THIS< thread:
http://www.skylinesaustralia.com/forums/topic/346495-sau-30/page__st__240
just copy:
And paste it into the "Deal Topic" boc. (but for the thread in which the "deal" started)
Hope this helps everyone?
im not 100% sure of what your saying i have tried to get trade rating working but to no success
https://www.sau.com.au/forums/topic/346495-sau-30/page/14/#findComment-5598714
Guys,
The 'report' function seems to be broken. I've tried to report a few spam posts - both the post itself, and going into the member profile and hitting report there - and in both cases it displays:
[#10135] We could not determine what type of content you are attempting to report.
Am I doing something wrong, or is there something special I have to do? Seems like what I'm doing should work?
Edit: d'oh just noticed others have reported the same thing. Any update on it?
https://www.sau.com.au/forums/topic/346495-sau-30/page/14/#findComment-5601950
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
