Peak Power at 5,500rpm! Noses over rather badly after 7,000rpm. He has HKS cams and what looks to be a 10cm exhaust. I wonder if its the std inlet that makes it fall over or simply the little 25G wheel running out of puff.
Would be a bit of an animal to drive with that graph. Makes me think Kando needs a T78 for all the RBDirty folk :)
I stick to my statement. Your always hanging around waiting and encouraging somebody else to try before YOU buy, I straight out don't appreciate that. There's a difference in attitude between quietly keeping an eye on someones build and purposefully encouraging them to hurry so you can see how it turns out for you own benefit. You have some audacity to talk about other members of this forum.
You can call me childish or whatever else you want, fact is I am an asshole and always tell it how it is. I'm not afraid to hear one more goof call me an asshole or a child or whatever else you would like to say, go nuts.
Fact is you and I watch the same threads, Ive probably inadvertently read 90% of your total posts, and I can safely say you have a crappy attitude towards this forum and the help you get from its members. End of story.
Do you really think I care what YOU think or appreciate??? RE: 'and purposefully encouraging them to hurry so you can see how it turns out for you own benefit.'..where are you getting THIS from?? Where did I say, 'hurry up, I wana see..' yada yada.. Even if I did, what is wrong with that/ Who are YOU to tell me what I should do?? Especially coming across as some stupid 'hero kid' with ginger just-grown pubes who thinks he can tell people what to do, you have been in here far far longer than myself, know more Skyline stuff than me, YET have very low levels of maturity and attitude. Grow the fk up you moron! I will ignore your posts now.
And of course I appreciate all the help I get on this forum, have said and thanked members countless times and helped others myself.
Either that or could it be that with those bigger cams the exhaust side is choking?
Edited by Rolls
I think the 25G wheel is just maxed out. If he had a bung in the housing seeing what the back pressure was you would get a feel for how the L2 turbine and 10cm housing are doing keeping up with the cfm from the 3L.
Wow, depressing to see how easy that thing makes power :(
Dam this is better then the plenum thread I opened haha can you guys make shorter posts makes the laughs come faster that's all. Hey dori throw the pop corn would you
Edited by Bsa
Interesting though that the low boost run that makes 300rwkw also has the same drop off, does that mean that its not the turbo running out of puff but something else?
The compressor follows its "pump curve" based on the pressure ratio. So whilst you are limiting your shaft speed the the compressors ability to keep up with the breathing of the engine is going to be roughly matched at low boost as it will be at high boost. That's from 10 sec think about pump theory. Others should jump in if that's wrong
Re bigger RBs...yeh yeh. I enjoy playing with the little 20. The way I see it the lil 20 is like a fine tuning fork. If it works in the 20 it will work on the other RBs, however you may not notice the difference on the bigger RBs as they have airflow to burn and not as sensitive to changes :)
I doubt the 25g is out of flow, I did go an extra 30kw more than that. I would be pointing toward the cam timing being a bit shonky like most RB30's... There is no way that should dive like that after 5000rpm and when I have seen them do it in the past it's because the cam timing isn't set correctly
EDIT: I didn't realise it was a shitty R32 RB25 head, so that is probably more the reason :whistling:
Edited by SimonR32
holy crap cake, that 30 would be devestatingly quick for a traffic light warrior with soo much torque at those sort of rev's. I'm deffinitly sold that if I'm replacing my turbo it has to be a TD06H-25G or bigger. KD do make TD07 and TD08 turbo's so no reason they can't make a T78. probly just have to ask to have them to list 1 on ebay or the shop front. they Listed other things after I asked them questions on selling parts.
But like you said it sucks at making power easily.... why do you persist??
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
