Its OK I don't take offense easily, and I'm far from a racist (even though I enjoy making racial jokes) so its fine.
Did anyone take note that Stao has started importing 20gs? I assume hes bringing them in direct from Kamak rather than Kando (they come unbranded). Hes noted he is re balancing them to a tolerance half the figure of original (twice as good) and is selling them at $850 with a Billet compressor wheel. That's pretty cool IMHO.
well i reported you ron/randolfj or whatever cause well ur crap is getting annoying..
its 156 pages or you living in this thread going on and on when it should be about 56 pages long of decent info/discussion.
you have 2 options.
get one of the hypergear turbos with the assosciated support mods
OR
buy the td06 that everyone else with an Rb25 is running lowmounted.. do the ext gate mod either off the manifold like Dori or off the rear housing as per Scottymn35 (sp?) and get the same supporting mods.
Go to unigroup or Jez as they have a great rep and experience with these things or similar.
smile driving home cause its going to be a f**kload more powerful than your stock setup and you are honestly too stupid to know the 20KW difference because if you had half an idea on what you were doing you would of noticed all this a long ass time ago when people started making the results.
here is your shopping list. with full names so you never get confused and wonder EVER AGAIN.
Td06sl2 - 20g
tial 44mm ext gate
Injector Dynamics ID1000's (there u go a nice helpful bit of info)
Z32AFM with plug
sell your JJR bellmouth dump/front pipe or chop it and have an exhaust shop make a dump to suit the rear housing of the kando and mate it to your existing.
Decent Electronic Boost Controller like the Greddy Profec B Spec 2
Front Mount intercooler (stay away from super cheap ones as they heatsoak remember? well there it is again so u know)
High flow 100cel cat or de-cat
3 inch full exhaust..
aftermarket computer or nistune chip
bigger fuel pump
k go!
dont post here again unless its to say u have bought all those listed above and are going to get it tuned..
Go off topic and be annoying as sin again and ill make sure you are banned for good :)
much love,
Aggro
To hell with you David/Aggroman, if you are so clever as you make out to be, then you will see in my signature what mods I already have, all I need is just injectors, gate, and the TD06 as I stated a page or two back. Have already got the Z32.
THANKS FOR YOUR SUGGESTIONS, if you had said in a neutral way, it would have gone a long way to merit approval. BUt it seems you are blinded in your own arrogance/ stupidity or havent really been following this thread / my other posts.
I dont know what your problem is, we dont know each other, and you clearly havent been following my earlier posts, looks like someones told u to write or u just takin a piss for having a bad day. I dont see where my posts have become annoying, all I did was ask some simple questions.
If you are good buddies with the moderators and wana ban me, then by all means do it, dosen't make a difference to me, dont bother hurling your garbage at me unless u got something good to say. UNDERSTAND??!!!!! k. GO. Ban me.
Edited by rondofj
Yes, yes i did, hence me stirring the pot first i believe..sorry rondo..lol
cheers
darren
rondofj - I have given you a 20% warning increase for your poor behaviour. Calm the hell down, or you WILL be banned.
Aggroman speaks the truth, and you should take his advice.
Always best to use a boost controller but it really depends which turbo u get. The internal gate turbo's seem to creep alot.
So best to use an external gate, in which u can then set the desired spring setting. I prefer to choose a slightly lower spring and use boost controller to raise the boost
Td06sl2 - 20g
tial 44mm ext gate
Z32AFM with plug
bigger fuel pump
k go!
much love,
Aggro
All this drop it off to me and jez and drive away very happy dori34 did haha.
ARTZ once your car is finished you should get Stao to back to back his Billet wheel version on his account to see if its worth the extra $100!
Would be really valuable data to contribute to the thread.
Yeah u can do it that way, I was going to till I realized my adaptronic had boost control..
Just chuck a 1 bar spring in and turbotech for tuning. When it's tuned to your desired boost put the extra springs in and ditch the controller..
Or while we are waiting for new members to buy in, or for you existing 20g guys to have your setbacks sorted :)
A good thread always has some level of garbage in it, and now we have a water injection thread to watch too! With upcoming results might I add.
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
