A thought just popped into my head...
makes me laugh a little
3 years ago anyone conpemplating a MHI/Trust turbo wouldve have been hunted down and shot and told that a GT30 or GT-RS is the only way to go for an RB25.....now we have people droooling over a cheap EBAY copy of an MHI turbo
only the puppets... been a trust / blitz apexi guy from way back... it only takes a few trips to real jap shops to see the creme de la creme.
Every drift car in aus with a genuine l2 on it came one way or another from me as did the rx6 kits.
now there is cheaper options it all makes perfect sense but 3 years back when we were using the ebay gear direct we copped alot of flack... many dealers got the shits as we were selling the turbos for less (1100 back then) and making less margin than the garrett equivs but got the results.
With me its never about the money (profit)... its about the result. Cats turbo was 2500 alone but its what i wanted and it gave the results.
so i was looking up different ways to mount an ext gate and across this method.. how interesting for those who used to run IWG versions but dont want to block it off simply take out the flap and do this.. oh and before you say anything this is working on a 500hp Volvo S60R
That would work but I think its inferior to the way ARTZ has his done.
His is the creme de la creme of factory position EWG IMHO
there is a difference between working and optimum and thats far from optimium, we tested that with the kando and it was still down on power compared to swapping out the rear housing for a proper ex gate item.
Your probably not wrong, I wont go there for now. Hate 'he said she said's', especially on the net lol. V8s did end up going E85 though, but with the guaranteed content CSR shit.
I have heard reports that eflex is fairly consistent at the e70 mark.. But I just cant get past the fact its a varying content fuel. Like I said in the HG thread, I fully believe in it as long as its used with a content sensor.
Once it properly rolls out in NSW and is available everywhere I will honestly be buying a flex capable ecu and getting it tuned on that :)
I just did a huge test (2nd round of independant tests) on a 420rwkw gtr (autronic eflex setup) last weekend and can tell you now that all the brands ended up with a big fat DRAW.
testing showed united and caltex to be on par and about 4kw down when at e70 compared to e85 on a safe normal customer tune so you wont notice any difference, yes the af changes between e85 and e70 as we all know but it is manageable and the 4kw difference shows the amount of change.
Tuned hard beyond the "normal" customer tune we found the 3 types of fuel to be on par and we got to the same peak power give or take 3-4rwkw which is probably more heat related than fuel related.
Graphs attached are the final 20psi results with -5's on bp98 and e85 and with the old garret supplied preloaded gates... which needed to be RE TENSIONED... bastards.
Oh gawd that is horrid..why do people think they can merge a WG in 10 inches from the turbine at that angle and expect it to perform well..
At the very least merge into a larger diameter pipe
That is fair enough and honestly not that surprising, but a little inconclusive in terms of the issue I raised. You are running an autronic eflex setup as mentioned so the ECU is obviously compensating for the difference. As stated prior I honestly dont have an issue with that and would happily run it myself (its just an expensive outlay when there are only 2 servos near me that sell the stuff, and both are 20k from home).
What I really want to clarify is the untuned and uncompensated difference between E70 and E85. I would like to see the result of a car tuned for E85 and then switched to E70, without compensation to the tune. IE tune a car with a Nistune to E85 and then fill it up with E70 and see what happens.
The reason I think stating only a 4kw difference is inconclusive is because Im not concerned about the potential of the fuel vs the motor. As I am confident you can extract more than what most setups can give on E70 making E85 redundant.. But that doesnt indicate anything to the mixtures and the resultant safety margin.
If you could comment on that scenario that would be great.
The reason I think stating only a 4kw difference is inconclusive is because Im not concerned about the potential of the fuel vs the motor. As I am confident you can extract more than what most setups can give on E70 making E85 redundant.. But that doesnt indicate anything to the mixtures.
results were done with the comp tables turned off. 4kw loss on E70 was the result of fatter mixtures. (with comp it stretched to 7rwkw)
I know the exact change in lambda between e70 and e85 as i get to see it multipes times a week. Put simply If you tune a car on E85 correctley and then fill with e70 it will get safer (provided you have not screwed the timing table way to far on 85) there is a small difference in timing requirements but the average tune done by myself has this compensated for even in non eflex situations.
All my e85 tunes are just as safe on e70 regardless of if they run eflex sensors or not.
thanks for taking the time to share mate, thats really valuable info
i wonder if all tuners would keep to the same margins. my biggest concern liesin a car tuned on e70 and tunedto its ragged edge, then filling up on e85.
either way, you have bestowed some faith in me. thanks,
This is interesting stuff.
So really you just have to make sure your tune is 100% done on the barrel stuff.
Then when you fill up at the servos that do change their content mix it will still be in the safe zone.
I like the idea of this because I currently am running a Nistune
Cant wait for NSW/ACT to get with the times and start supplying.
lol...im not sure mine is creme de la anything..buts probably as good it can get for what it is..:laugh:
We are going to plumb it in, screamer doesnt do it for me..
it will plumb in just before the cat on a very slight angle, 3' and 2' Into 3.5'...i will run it on the dyno to see how much is lost doing it..
Not exactly as the drum e85 ie sucrogen is a higher octane
Had another fail tonight with the internal 20g. Customer has modified the gate and the dump pipe but still boosting up to 22psi. After inspecting though the wastegate arm isnt moving freely. It seems as though the bush has failed when he has heated up and welded the internal gate etc.
So i gave him my old ebay 38mm gate to weld on and try.
Retune on monday or so.
Hoping but cant promise i can tune the drifter tomorrow during the holidays. If my boss lady lets me
Jez man just smash that POS housing with a big hammer, tell em to stop wasting your time and not to come back till its built properly..
Act has 2 servos ;)
FYP..
No shit last time I was there I got sick of looking and drove to Yass for fuel..
    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
