Odd, I ran a freddy manifold on my RB25 with a GT3076 at 18psi.
RB25 - 314rwkw 750nm torque
RB25/30 - 320rwkw / 850nm torque
Ahhh, just read that you have a RB20. Surely that won't make too much of a difference?
no im running a stock rb25 motor with arp head studs camtech 272 cams. yeah not sure, might be dyno who knows. its never seen that kind of nm. similar setup cept plazaman gt3076 .82 and e85 made just under 600nm on same dyno. who knows. see how it goes at drag day in september. should trap ok mph im hoping. the cams are suited for a larger rev range, i only go to 7200. these might make more torque over that,but stock motor , keep it at 7200 so it stays together
Edited by methz
Definitely something wrong with that torque reading. Mine was done on two different dynos, and same reading.
So don't lose faith in your freddy manifold just yet. You'll find that is not the problem.
Power is up there - just the torque is not quite right. MPH will definitely be an indication of what you're really running.
Good luck!
I'd imagine you are talking about a dyno dyanmics torque reading (tractive effort)? You can't compare that to a dynapack...
Mine made 590nm on similar power so methz result is just about spot on
Edited by SimonR32
Mine was one dyno dynamics, and the other was a mainline, both had similar readings
  • 1 month later...
Hey guys flicked through this thread but just chasing info...
Had a kando on the Sr and now picked up a pooline. Just wondering whether the 4inch covers on the td06 25g fit low mounted. Aside from a spacer plate and extended studs I'm wondering if they foul on a stock rb25 manifold anywhere. I know the 3inch fits indefinitely but I already have some cooked Chinese low mount unit on there now with a 4inch pipe that I'd like to reuse if possible. Cheers
  • 4 months later...
Thread revival.
I've been away from skylines for far too long and I'm coming back. Looking at these turbos again and can see they have the new bolt on internal gate versions with the adjustible gate.
Are there still boost issues if running Internal? Td06sl2-20g in 8cm for response and direct bolt on.
Mods: 550cc nismos, z32, nistune, other usual bolt ons.
Any input would be good. Or am I better off going hyper gear?
Chasing 250-279
Hypergear internally gated Rb turbos are definitely better, and so's externally gated. check out other member's results in their thread.
I disagree. Kandos are the next best thing to precision and garett. So cheap, and well built.
just proof there i've been away for too long, i called the actuator - 'gate'
hmm ok 10cm internal gate, any dyno sheets with stable boost? looking to run 18~ psi on unopened RB25DET.
I'm posting this to save you some money. This is a kando TD06 in a 10CM turbine, notice the boost creep and tapper.
and I have received many of turbine housings of this kind to re-work on its internal gate. From the way of how the turbine housing is cast, internal gate can not be effectively enlarged either.
Depending on how much power you are targeting. our STD high flows in most of cases can reach your goal with better performance and longevity.
21U STD high flow, E85 fuel.
Perfect boost control. Internally gated.
Thanks Tao, i've been in contact you on FB via PM about the hiflow as it looks to be the way to go
unless there is other evidence and feedback with the int gate with kando, will be going hypergear. i had their ext gate setup and it was great. but want to keep it all factory looking now
Cheers
Anyone had a turbo highflowed with one of the kinugawa GTX compressor wheels? I have a pair of -5's that i wouldn't mind cramming GTX67 wheels into.
http://www.ebay.com.au/itm/Billet-Turbo-Compressor-Wheel-Garrett-GTX2867R-49-7-67-4-Trim-55-11-0-/271774042157?pt=LH_DefaultDomain_15&hash=item3f46fec82d
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
