this is the connector for the atessa bleeding in a c34 (unplug it and it will run the motor continiously )
Looks like we have something similar, found this in the workshop manuals..
With the rough translation from Google being
3. The key switch to ON state without starting the engine.
4. Remove the connector for the driver side Insutoroa of bleeding.
Been cut off by removing the wire connector •, entering into an air bleeding.
The motor drives the pump at the same time, stopping after a few seconds. In this state
Constant pressure causes the actuator transfer
  • Nope 1
will have a look at that this arvo!
Those workshop manuals come in handy. Hopefully the plug taped into the OBD2 loom has the answer. You would never know about it otherwise.
Let me know how you go Craig, I will do mine too.
and me!
Well it does run the pumP....just need to get motivated and bleed it now.
So that's what that does (just tested it). I unplugged mine when chasing to see why my infometer wouldn't work and it threw up a 4WD light. I never unplugged it with the ignition on tho. It looks so aftermarket & not factory at all, unless my connector is different. In the end I had to take a wire from this connector & feed it back into the ODBII plug to allow the infometer to pick up the CAN signal, so mine must have been changed at some stage. Nice find, thanks.
I don't know if m35 is the same as r32/r33/r34. But if it is:
You will not loose xfer case oil if you drop the front driveshaft. There is a seal
The system will always bleed when the motor is running. Once the accumulator is empty the pump will start up.
There is a second bleeder just above the rear driveshaft (in addition to the one at the gearbox). 9 times out of 10 you don't need to use it, perhaps this is the 1 time.
Decided to smash out my fog lights [ stagea s 2 ] a bit of a hard job to break into bits and get out .Looks heaps better
I did this a while ago, thought I got all the pieces out, then after a few weeks of driving I notice some little bits of yellow glass still in there lol
Can you see what happens if you unplug that plug, start the car and then push the brake pedal 5 times? (if Nissan were nice, it should go in to 2WD mode!)
  • Like 1
As soon as you start driving the 4wd light comes on, looks like it works just fine. I dont know if I would trust this method on the dyno unfortunately. If the pressure ever came back on it would be interesting to say the least...
Have you bled yours yet Craig?
if its as easy as that to disable. im rigging up a switch :)
Iain i did it to mine, it doesnt feel to good after abit of driving in 2WD. the car seems to vibrate in park, or idle.
i plugged it back up to see a difference, and it wasnt vibrating after a drive...
I thought the torque feels better in 4wd, cant explain it, but i think i liked 4WD better.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
