buy a commo.... single wheel skids is obviously your thing. :nyaanyaa:
Or spend the 1k on a LSD and make Jetwreck jealous!
Dropped exhaust in today to get a few more inches- My measuring sucks. Has anyone with a NM35 found if the V35 coupe midepipe fits...? larger pipe, single resonator and CHEAP!
Edited by PN-Mad
Built myself a polycarbonate air box to go around pods, I've got air coming in from inner guard, behind head light + i've kept the factory snorkle coming in the top.
Intake air temp has dropped about 7 deg on average.
As soon as you start driving the 4wd light comes on, looks like it works just fine. I dont know if I would trust this method on the dyno unfortunately. If the pressure ever came back on it would be interesting to say the least...
Have you bled yours yet Craig?
In C34's a solid light (should start flashing after you've pushed the brake pedal 5 times) coming on when you start moving is an error.. be careful as if you've unplugged the plug and have a solid 4WD light (at least in C34's) you're in full 50/50.
thats what i thought. tried spinning the wheels up on gravel and didnt kick out with 230kw. i think i may have gotten all foour spinning though.
does the car have to be in ignition, or running when you press the pedal 5 times..?
this doesn't work Aaron...pity too!..........if you want 2WD just unplug the front ABS plug's going to the sensors....easiest way and it work's.ph34r.gif
PS. Your car will still not wheel spin from stop even with 2WD....it may or may not break traction when it comes on boost depending on road surface......It's 2t, auto, 2.5lt, has dumb arse TB restrictions and long diff ratio's!
Edited by Jetwreck
i figured, i guess the 4WD light on means permanent 4WD, just get the f**ker checked lol
is unplugging the ABS safe? as in i kno it will instead skid to a stop, but driving around like this is safe?
pictures on how to do it.. lol just to see.
lol......once upon a time there was not ABS!thumbsup.gif....ABS was invented for people who don't know how to brake!...I don't think I have used it in an emergency even though I know I have it!.....in fact if you brake on a dirt road you are better off not using ABS as you can stop better without it....if you know how to use a brake that is!nyaanyaa.gif
picture on how to do what....a burnout!....lol!
  • Like 2
THIS
I reckon EVERYONE should learn how to drive and have to take the driving test (which should include an "advanced driving" course) in a pre-1985, manual car.
  • Like 1
THIS
Totally agree....more to the point I think Insurance company's should have a discount scheme for those who choose to do those courses!
  • Like 1
THIS
I'm alright. I'd take the Datto. :D Stops better repeatedly than most modern cars :whistling:
+11ty to all the braking comments above.
As for 4WD>2WD, car has to be started, it will work if you just turn the key to ON but resets when you start the engine so you have to pump the brake pedal again. If successful the 4WD light should come on and start flashing.
As Jetwreck said above, it's not going to light up standing on it from stationary (hopefully it will when I get my 3L bottom end in :D) but from about 4000rpm with VCT engaged it lights up, 5000rpm without VCT. Sit it on the brake, wheels start turning at about 2500rpm, slowly climbs to 3000rpm where it starts to build some boost, about 3500rpm it's making significant boost and skyrockets to the limiter.. bounce limiter once or twice and click 2nd, release brake, super fun happy strips time!
NOTE: this is from C34 experience, but seeing as how Nissan like to not recreate the wheel so to speak, I'd be interested to see if it is the same for M35 and would be surprised if it's not :)
  • Like 1
Going to be adding a bit of oil capacity & trying an interesting budget brake upgrade...
Edited by Daleo
Cool. Interested in the reasoning behind going with the oil pan spacer instead of an oil cooler?
It was cheap & simple.
I can't really justify the expense of a cooler setup with an oil thermostat, and that's the only way I'm prepared to do it; so more oil+deeper sump is a win for me right now.
That and it was a box filler for my brake brackets...
Edited by Daleo
These spacers have the fitting for oil temp right? I wanted to get one too but wasn't 100% it would fit. (plus I really should make my own.) :)
This one doesn't, but I'm only a threaded hole away. The one that did have it was another $30.
I'm about to find out if it'll fit, if not I'm sure a V series owner will take it off my hands.
Edited by Daleo
Probably, as long as you can find a mechanic to fit it for them :P
Waiting with baited breath for the results of the adapters!
So I might be able to make some more money fitting it for them?whistling.gif
Me too Andy, roll on weekend for the mock up!
Lets see how good my measuring is... Only other issue I can think of, is that the rotor radius may not fit fully inside the caliper.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
