OK so I got my new grill today....sprayed it up and fitted it.
Thoughts!!
In my old age I am starting to LUV black. :rofl: :rofl:
Some gentleman ran into the side of the N/A today. Not too bad, about $1500. We were stopped at a light and the dude just drove into the rear P/S bar.
Thats fairly impressive, you managed to take two photo, minutes apart & from an identical position, with your finger over the lens both times :P
Looks good !
P.S. It's the case on my Iphone4 not my finger's leaving the mark...lol!
Edited by Jetwreck
The new one, probably because its a bit similar to mine :whistling:
ahh damn! glad youre ok mate
i think they need to do annual testing of older drivers from 70 now.
i got taken out by a 74yo lady who said she had a green arrow to turn. except she wasnt at that intersection.
I've been saying that for over a decade. If they can clamp down on p-platers driving turbo cars, how about annual testing for those idiot elderly drivers!
I see elderly people making big traffic blunders all the time. At least twice a year we get them driving the wrong way down the freeway/expressway.
:down:
The conditions today were clear, dry roads, total visibility ... yet he didn't see me :blink: Time to give it up gramps.
Just put a 32gtr blow off valve on the M35. fits nicely, sounds better...
just need to find a radiator hose i can stick in to make it plumb back again..
i dont really know what this is going to achieve however. i was bored and had the car apart in the garage
Bought one: http://www.northshoreprestige.com.au/view.php/used_cars/2001_Nissan_Stagea_250tRS_FOUR_White_5_Speed_Automatic_Wagon/4470190/
Does that count? :P
Plan at the moment is major service first and foremost.
Then need to decide next move. Intake runner spacer, exhaust, coilovers or front mount probably. Still undecided.
Bought one: http://www.northshor..._Wagon/4470190/
Does that count? :P
Yeah, I reckon that counts :thumbsup: .
I love what happens when you click on the link. It says "Sorry an inventory issue has ocurred". Interesting way of saying the car has been sold.
blacked out the headlights today, had to take the left one out to fix the seal as i saw condensation in there other day.. and thought while im at it may as well get the blacking out of the way.. I love the look..
did the oil and filter aswell.. once i put it all back together my engine check light came on.. anyone have any thoughts as of why??
im thinking when i moved the airbox and bumped the A/F meter just the usual amount when moving nothing violent..
it shoudnt be to do with the lights right??
anyways enough work for today i will run diagnostics tomoro.. see what i find..
car runs fine no different at all..
anyway pics
sorry for the bad pics its the iphone 4 in a carpark... never a good combo!!
Nah, won't have anything to do with the lights.
Did you have the car running with the AFM unplugged? Doing so always brings up the CEL.
If so, it will go away after a little while.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
