i used a product called Glassylite to restore my headlights.
i used to use Meguiars PlastiX but found that they would just yellow up after a couple of weeks.
with the Glassylite, you are basically cutting back the polycarbonate lens, polishing it with lighter grade compounds as you go, and the final step is a nano-sealant which seals the plastic again. 6 months on and no yellowing, they look brand new. best 40 bucks i've spent on the car.
ive heard about glassylite, if your saying its the goods i might give it a shot
Scott's hi flowed turbo and injectors are now on my car...he probably cursed my name all through the 3 days he was working on it LOL.
Emanage installed by Cihan last nite, trans cooler installed by Aaron last night in the rain...thanks guys!
Got my shift kit installed today at RVO Auto. Rob's done a good job. As per everyone (Scott, Cihan, Aaron)'s advice, I asked him to make it "as firm as possible".
He said he'll do it after checking out the state of the tranny.
Opened the sump, no metal shaving, trans fluids look almost new. So he made it firrrrrrrm
Haven't been able to enjoy the car too much in its untuned state...hmmm
Also dropped the oil and put in Motul 8100 Xcess. Was too tight to pay for 300v Chrono :blush:
I head to Sydney on the 6am Qantas flight in the morning to pick up the car! Apparently its a train to a ferry, then Ben from Northshore will grab me from the ferry.
First bit turned up today, a Nismo Veruspeed oil filter. Just waiting on the Blitz air filter and Denso plugs, and I'm ready for the service. My local Repco stocks the whole Motul range, so I'll pick up some 300v and the Motul RBF600 brake fluid Iain recommended. No Nulon trade dealers in SA according to the Nulon rep who called me Monday, so my only option is to get Repco to order it in (was about $120-130/20L trade) or go to Sprint Auto Parts, which was what Nulon recommended.
Looking forward to the drive. Didn't take the day off work, worked the hours Monday and Tuesday instead. So while I'm a bit tired, I don't really have anything to stress about and can just enjoy the 1,400 km drive! Have packed my 7D, tripod and remote for some happy snaps along the way :D
  • Like 1
i got my my new rear exhaust section fitted up today.
started off with 2 x 500mm sections of 3 inch pipe, 1 x 3 inch y piece and a 3 inch flange
the y piece is actuall 3 inch inlet into twin 2.5inch outlet so the pipes will need some adjustment to fit
old vs new, just needs some paint after the test fit
all fitted up, clearance is all good, just need some paint, it is a bit loud now at about 3000rpm, i'll prob just throw a hot dog in the system further up
Edited by Big Fella
Hey Ironpaw, that's a long list of work you've had done to you car over the last few days. I love it how everyone chips in to help. I feel all lonely up here with the only M35 in the area.
Anyway, it sounds like you're progressing well, and fast. Look forward to the reading about the rest of the mods.
how much to make me one? i was thinking about buying on
in other news, i grabbed some of the GW syn-x 3000 this arvo, $32 for a semi syn - will see how it goes tmrw
also grabbed a meguires clay bar kit thing, should have super shiny paint soon :D
Ha ha, yeah the gaurd rail won. I actually felt really good at the time, straightened my back and neck out. Anyway time to get rid of it though i have to drive the gtr to work now til i get another daily.
Kinda ironic cause i had new wheels and tyres (volk ce28n in other post) that ive been holding of fitting cause i didnt wan2 scratch them, if i didnt have bald tyres on at the time it would of never happened.
Oh well shit happens.
well i got up late this morning, and was already late for work so thought f**k it, im gonna fit this grill
looks good, im kind of happy i didnt colour match as now it works well with the ARX gaynus styled moustache :ph34r:
tell me what you think?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
