Trans cooler installed.
Reprogrammed valve body in transit from Jetwreck. Thanks Craig, you're a champ to fit me in so quick :thumbsup: .
The other day i had my tailgate open at the super market, closed the tailgate and there was a loud bang. Then tried to open the tailgate and it was really heavy......The strut had SNAPPED on the ram and snapped the bolt in the thread on the roof side post-41430-0-79806300-1322732411_thumb.jpg pinch.gif
So I sourced a new strut (second hand), drilled out the old bolt...sort of, snapped an ezy out trying to get it out then had to drill/dremel and heli-coil.....C#*T.......but at least now its all sweet again though.
Adjusted tail gate glass as it was sitting out from the rubber seal 5mm.
And installed another screen that I scored for free from a mate (sound doesn't work out of it) installed new pure sine inverter in the back of the car and a ps3 in the tray above my spare wheel, just velcroed to a chunk of rubber then to the tray.......
Just need to work out how to hook up the ariel to the "play tv" unit for digital tv through the ps3
I finally got the 34 rims on. They actually clear the brakes AND have enough room for wheel balancing weights....big step forward in my world....
looks good :)
Which trans cooler did you go with Leon? I got my B & M today, just need to make time to fit that and the shift kit.
Also got my fuel filter, Nismo thermostat, and HKS sensors. Streeter excellent as awesome.
Moving this weekend, but once I've moved I should have time to get into fitting some of the thousands or parts I've built up again.
Had a similar thing happen to mine about 2 years ago. You were a bit more resourceful in getting the bolt out as I had to pay some one to get mine out and that was expensive. Replacement bolt was only $5 from memory.
There's always a story, lol... I've had one in the shed for 6 months or more but now with the fmic inplace it was too big to fit nicely. I went to a local auto parts store & bought a generic one (Davies Craig brand I think), chosen purely on size & availability. I figured with all the ATF drained, there was no time like the present to plumb it in. The instructions were adamant it had to go after the radiator for the coolest possible fluid to return to the trans. I did the opposite, as per a fairly common consensus on here, & went trans > cooler > radiator > trans.
I've been keeping count mate, & I think your estimate of parts ready to go on the car is low :P. Good luck with the move. Do you realise that if you installed everything you wouldn't have to move them??
Thanks for rubbing in in you bastard! :nyaanyaa:
I have a better plan than that... half the bits are sitting at dads work next to his hoist. The rest will relocate there shortly, and I'll fit them there too. Next to fit is the cruise control, controls on one day, rest on the next. Hoping to fit the shift kit and trans cooler together after that, then fit and rewire fuel pump. TBH my B & M trans cooler looks pretty similar to yours, except mine is black and everyone knows black is cooler than silver.
Good to see you have a plan :happy: .To have a hoist (drools) would be great, but so far I've managed most things on ramps. Call me when doing the cruise control if you've got questions.
10 secs with the spray can & I've got a 'cool' B & M. Nice, thanks for the upgrade suggestion, lol.
Yeah It was a bitch to get out, they do them up farking tight from the factory..... I haven't snapped an easy out since I was an aprentice :mad: , so I was pretty annoyed at the time...... I made sure the second hand strut came with the bolt though.
TBH your trans cooler looks identical, except that it's silver instead of black.
With the cruise control, looking at your thread installing the buttons is pretty much plug and play now you've supplied wires with the right pins on them, right?
Plug & play, sure...:whistling: Nah, you'll be fine, but you've got my mobile number so please call/text if you have any questions. Just watch the removal of the Torx bolts in the steering wheel. I recommend turning the wheel so you can get at each one from out the drivers door. You need to ensure you get good access & be straight on when you apply torque to undo. A guy yesterday may have rounded off the inside of one of his.
Want to come and do mine, it snapped weeks ago. Lol
Havn,t broken a bolt yet, but the struts seem to grind and then clunk. Have a spare tail gate with struts so willtake them off and fit up.
Looks good. How do you access your a/c controls and the other controls?
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
