Tried to install FM band expander but once had pulled the stereo out realised that the one I've got does not match the aerial plug for the stereo. Sumofabiitch.. Put it back together and I'e got 2 screws left over, not sure what for though. Damn.
Went and saw my painter to get a quote to repair the vandalism on my car; I think he was more pissed off about it than I was!:spank:
Looks like it will be around $600 to repair; he's confident he can mask around the rear glass, and this will mean we can do the whole rear quarter/cant rail area, rather than "blowing in" the top of the C pillar. The quote also includes repairing the additional foot long scratch on the DS front quarter that I didn't notice initially. :angry:
Considering doing the other rear quarter/cant rail to correct a mark from the previous owner, and possibly the tailgate while he's there.
See what happens in the new year.
Edited by Daleo
just respray the whole car :P
It's not entirely off the table yet; most likely just rub back & re-apply the clear, if I decide to go that way.
But have I then made it even more of a target?:angry:
Nice try Banana man! :P
I'll let Leon answer it though!
Yes, I was waiting for him to answer...you poor sex starved SOB...:nyaanyaa:
just sayin'... "Can't fault it" sounds a lot more conservative the all the toher "OMFGBBQ IT ROKZZZZZ +10000" responses that others have posted after the install...
Edited by ironpaw
rofl.gifyou met Leon?
Talk to your Vic installer if you have doubts Jethro.....Scott!
Edited by Jetwreck
Hey Jethro, sorry for not being more enthusiastic about the Transgo kit, lol. It may have read like I was a bit 'meh' about the whole thing, but that is far from the truth.
I've read pretty well every post in every thread on every forum relating to the VB upgrade, & except for a few unfortunates who probably stuffed theirs up, the results are mostly the same. So, after testing mine & finding it performed exactly as expected, that's what I posted (honest as always :happy: ).
I've been thinking about how Transgo developed the HD2 kit for RE5 g/box. Given their target market was probably the Infiniti G35 (sport/luxury), I think a HD1 would be too soft & slow & a HD3 would be too harsh for the majority who don't track their cars. I reckon they got it bang on with the mid range kit & suits our cars IMO.
But if you want more details, so I can be added to the "it was a fully sic upgrade bro" crowd :P , then here goes:
On launch the wheels spin for a noticeably longer time.
I haven't yet experienced the chirp into 2nd gear at WOT. Maybe too much grip, maybe not enough power, either way a little bummed. However, maybe the TCU will learn new parameters after a while & it could happen (could be a Pantene moment, lol).
I took my missus for a drive and, while driving on light throttle, was boasting about how smooth the changes were. Later she says 'how much money did you waste on this?' & I put 2 & 2 together & came up with she was disappointed. So I put the boot in & all was forgiven :wub: .
I admit I've been more excited by other mods I've done, but that was more to do with the unexpected results than anything else. I love spending a $2 & getting a great result (eg brake wire cut) & even though the VB upgrade wasn't cheap by the time you put a cooler in, fill it with ATF etc, it is still excellent value & a 'must do' for anyone wanting to get more power to the ground reliably.
Nah, I've already got a kit in my gearbox and I'm through spending more $$$ on the car....
althought I did drop off the car with the gas mob so they can fit larger jets in....then get a retune with Cihan....althought Scott might have to drive the car there :whistling:
Has anyone noticed the 1st to 2nd change isn't as firm as the rest? Still a big improvement over stock but not quite as firm as the other changes. Unless I'm not putting the boot in enough! I'm still yet to do a full throttle shift in it since I fitted the kit.
I haven't noticed as yet. I thought they all felt roughly (smoothly? lol) the same in the brief drives I've done.
if you stomp on the gas and try shift from 1st gear at 4000rpm it still hits the limitter twice before it changes but its alot of fun HAHA
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
