Sounds good... how much?
At this point; they don't even appear on any of Whiteline's listings. Basically hot off the mould.thumbsup.gif
Cheers, Dale.
Cheers, Dale.
Put me down for a set Dale for when they are available... The sooner the better :thumbsup:
Don't wanna wait until they cool down off that mould!! :teehee:
May as well get my name down early...... :cheers:
http://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash4/378116_264514910273122_100001438467673_766361_388568872_n.jpg
http://a2.sphotos.ak.fbcdn.net/hphotos-ak-ash4/384517_264511256940154_100001438467673_766334_1265676649_n.jpg
hopefully these work. just finished installing 40 min ago. so buggered, R34 GT-T Calipers, Bendix Ultimate pads, DBA 4000 series T3 rotors all round. havent had a cars brakes feel so strong during bedding in like this set up is :D cant wait to test them in the hills after a nice city drive during day tomorrow.
Nice! Ive got the T3s and a much better package than I had. Did you change the fluid yet? Ive got some fluid and lines to go in still, should improve pedal feel.
If I get that nostalgic, I'd rather go in a good c34 stagea :P
Thanks for the offer tho, but I'm over cars for today at least. New rig got defected today, right when I need it to tow the boat (an actual boat tho, not an m35)
LOL, towing an R33 around will always get you negative attention... :P
yea i upgraded fluid to DOT 5.1 at the same time, to help when in the hills. nd then ill be saving up for braided lines eventually. but need to start saving so i can get around to purchasing a house next yr. i started off with more money then i currently have. so over spending atm :(
Finally got around to change the cam cover seals. At the same time I cleaned the corrosion off the cam covers & gave them a coat of paint.
Before.....
Cleaned......
Painted.....
Fitted.....
Went to take it for a spin & blew a hose off the cooler, 5 minutes later found which hose it was. Reconnect & the POWA was back. :thumbsup:
Oh yeah, I recieved something in the post last week too.
Just picked up the same one, looks like a great kit! :thumbsup:
Where are M35 owners mounting theirs? I thought I'd fit it next to the DVD-ROM above the glovebox, but it doesn't fit (unless I cut into the ribs of the cover, that is...)
side piller
Gas joint rang to tell me they've fixed up my car...there was a leak in one of the lines and the pressure in the gas tank was low. Looks like its time for a retune!
The guy also said he noticed the CEL and checked it with his scanner which returned a "missing O2 sensor" error. He was a bit bewildered when I told him I don't have one on my car...
I was surprised that his scanner could read the CEL though...considering that this gas conversion joint work mainly on falcodcores...and that our cars have some weird non-standard OBD2 thing...
Edited by ironpaw
If that's all thats causing the CEL, why don't you just run a wideband with a programmable narrowband output and feed that into the ECU so it thinks there's an O2 sensor? The AEM and Innovate ones do this I'm pretty sure?
They only feed the narrowband signal that would have been there, not whatever you want it too. We are running no o2 feedback otherwise the stock ecu will add fuel all the time and we only want the emu to do that, especially when ironpaw has a switchable liquid gas system and e85 running with the Emanage on the one map.
Disconnecting the o2 will stop the afr's cycling and allow us to lean out the fuel on cruise. Our ecu's also play with the afr's well into the boost area which sometimes isnt safe. I had mine connected for a while but I realized it has thrown many other codes like ignition etc, may as well disconnect o2 and lean out the tune a bit.
Enjoying having a car again.....still has the CAS issue but will run without it connected....the only downside is it's hard to start and it has no advanced timing....but the upside is it has shit loads of torque and once boost develop's(18psi) the thing still goes well(e.g.enough to still break traction in the wet in second).
With the emanage gone and back to standard injectors the Diff's were are great investment......feels like it's had a 400kg diet!
P.S. I cannot wait to find out the miss fire issue with the CAS......bring on some advanced timing!banana.gif
That's great news Craig. I hope you work out the CAS issue soon & get back up to full power. No problems maxing out the standard injectors? I reckon they are highly under rated, especially if you've increased the flow via better pump or FPR.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
