I have been tinkering with underbonnet temps and air intake temps lately and had a go at making my own air intake.
I already had made a perspex heat shield quite a while ago, but there was nothing to help get cooler air to the filter. Our cheap, nasty mistral dryer karked it the other week and when it did i noticed it's air duct at the back was quite nicely shaped. But it wasn't long enough to do what i needed.
Oh, Hi there black plastic garden barrier roll !!
So i cut up various shapes of plastic to do what i needed. Then I used a heat gun to shape the plastic to the dryer intake and to clear engine bay stuff. Glued it all together and sprayed some matt black on for good measure.
It definitely works. On the highway, i can feel a quicker response from the engine. Would love to run a temp probe of some sort and do back to back testing with it on and off so i have some figures to match what i think is a very positive improvement.
post-58831-0-49410200-1330504937_thumb.jpg post-58831-0-80538300-1330504949_thumb.jpg post-58831-0-87838900-1330504956_thumb.jpg
The other thing i have done, is cut away a section of the rubber at the rear that seals the bonnet to the engine bay. This is on the exhaust/turbo side and lets alot of hot air out. After stopping the car i can tell the difference just by touching the bonnet in different places. It's alot cooler at the air filter end, and just warm at the turbo/exhaust end. I've felt my bonnet temps for along time prior (just for curiosity - ok, i'm weird) and this small mod has definitely helped alot.
Nice one Jezza :thumbsup: . Stuff like that provides maximum bang for buck because you hardly spend a buck (just a bit of time).
I couldn't let it pass without giving you the thumbs up; my sig says it all.
Thanks heaps Commsman. Ok this one's for you then
Take 2 -3 old 3.5" Desktop hard drives. Dismantle, and retrieve awesome magnets. Link together with wire and wrap around oil filter.
post-58831-0-76312200-1330507420_thumb.jpg post-58831-0-25674400-1330507427_thumb.jpg
Now people are gonna say, whatever, there's alloy filings that it isn't going to get etc.... well non ferrous metals can still get energy from friction motions (crankshaft rotation etc) so they will be attracted to a magnet.
Haha. ummm, yeah, that does qualify I suppose.
I'd be concerned about that bouncing off under the car & giving me a mild panic attack as I (however briefly it may be) think something important has busted & fallen off. You probably won't see that one appearing on my car anytime soon, but I'm sure it is effective nonetheless. Looking thru the emoticons for a 'half thumbs up', lol, but no luck.
HDD magnets are absurdely strong, they wouldn't 'bounce' off imho :P
Oh?
Ok then, Jezza :thumbsup: for you recycling junk into performance & maintenance enhancing thingos.
Norwood Auto Services dropped off the car this morning...
New ball joints
New SuperPro bushes
New SPC camber and toe bolts
New adjustable rear toe arms
Handling is much improved. Much less freeplay than previously, feels great.
Still feels like it pulls to the right, going to switch the front tyres around tomorrow and see if that fixes it. Regardless, I'm going back next week to get wheels and tyres sorted, so all good.
Also test fit the new wheels, fit perfect. 18x8 +34 Braid Winrace A, white. In stock with SA Motorsport Tyres, Just trying to decide on tyres now. Looks like 235/40 R18 of some description.
Had plenty of time to drive it, 800k's over to Calder Park for Rally Calder this weekend. Cruise control is a godsend Leon! Works great!
White on white hey.... look forward to the pics when fitted.
Why so small on the tyres? Is 235/40 a common size for ones you're considering? 245/45 is much closer for speedo accuracy, plus a bit of extra sidewall to absorb big holes. Of course if you want more of the low profile look then they would be ok, but I'd consider going to 19's if that"s the case.
Yeah, I'm loving the cruise too. I use it nearly every time I take the car out.
PS For those last few guys waiting on theirs, I'm in contact with my buyer every week & they assure me they are going to be sent soon. I think the factory has discovered what country they are coming to & is taking their time sending the last of the harnesses, just to punish me.
They did look good on the car but we ran out of time to do it on Tuesday.
235/40 looked like it'd measure faster than 245/45 but I'll check when I get home again. not really after low profile, more the right size. Staying 18 though.
+1
With that offset you can easy fit some 245s in there. Do it. Fill the guards with rubber!
Ryan on my 18's I run 245/45-18 and the speedo is now only out about 2-3km instead of the previous 10km I had measured. Deffinately go a 245/45. So when the speedo shows 60 I'm now doing about 58 actual speed, before it was closer to 50 actual speed when speedo showed 60.
Can you get those wheels in a +20? I think they will sit in the guard a little to far in the size your looking at. Not sure if you remember where mine sit but the size your looking at will sit inside another 16mm from my 18x9+30. Mine sit very flush and don't scrap at all with my tyre size and ride height.
Edited by slippylotion
Weird that yours was so far out, must have been the snow tyres. Mine is about 8% out I think.
will go the 245/45s, just limits tyre selection.
245/45/18 is OEM VE Commodore sizing; plenty of reasonably priced choices in that size.:thumbsup:
All good Paul, happy with the offset on mine. Look good!
Thanks for that Dale. Of the two tyres I'm looking at, one comes in 245/45, one doesn't. Cheaper one does!
I have been thinking of doing something like that for a while but can't bear cutting away stuff, good idea to dump some heat out there. My bonnet lining was getting all tatty looking & fibres dropping out onto the motor so I removed it, bothers me that the paint is feeling more heat. Still heat can radiate out better and a bit more air space.
Back in the jurassic era when my old holden 186 turbo roamed the earth, under bonnet temp got way higher than any of it's peers. The 3" dump pipe and Rajay turbo scroll and cast manifold would regularly glow cherry. Think I had spacers under the bonnet hinges to lift the back a little.
Is this the factory Bose spare wheel sub into a non Bose factory head unit? Please PM connection details if it is.
Cheers
Hey guys
it really wasn't so difficult. All you need is to find the wires for the power, earth, remote and speaker and fiddle with it. I had it connected into the amp so it didn't come directly from the HU. It still uses it's in-built amp though.
It honestly wasn't hard you just need the patience to still there and play around with it.
received my order of LED T5 globes for dash last night. work really well :D few darker spots but better then previous cars i have had.
also received my front and rear strut braces today. :D fitted, but need to loosen up rear sway bar i think, went from understeering a fair bit to oversteering now. otherwise still plenty of fun :D
Here's what I've done to the car since purchase...
Hdi FMIC, Transgo shift kit, Brembos from 60th Ann 350Z, custom 3" exhaust with Scotty's dump pipe, uprated sway bars from Selbys/Fulcrum, PWR transmission cooler, LED daytime/fog lamps, air horns above FMIC.
Still to do - bonnet strut kit (no garage and it's been raining constantly in the Mountains), EBC, possible info meter and double DIN DVD/CD + reversing camera + navigation. Considering a Scheel drivers seat I've had since 1988, big wrap around shoulders and still in good nick. It's migrated from car to car.
Some new wheels to replace the T7s.
Attached is a photo taken before the foggies and transmission cooler.
More photos to follow.
Edited by rosella
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
