This is what I'm aiming for, what's your setup?
Autech 260RS
Stock bottom end
Stock FPR
R34 GTR turbos < Terry's old turbos :whistling:
Nismo 555cc injectors,
Walbro fuel pump
Power FC
AVCR
Z32s
Greddy suction kit and cold air box with factory snorkel
HKS 264 deg cams
HKS cam gears
HKS hard piping kit
Yoshida Garage custom ported head and port matched exhaust manifolds
Greddy extended split dumps and front pipe
Fujitsubo Cat back
Gutted cat
N1 oil and water pumps
Greddy oil cooler kit
Turbosmart BOVs
312.5kW at 16.5 psi
272kW at 13 psi
yep, the jaycar kit, works perfectly. Just tapped the speedo wire at the dash and hid the box up behind the hazard light switch. It's been in there a while bu I had to adjust it because I've changed rim/tyre size recently.
Nismo dash is the main reason I had to fix the speedo. A big digital speedo is just annoying when it's wrong!
Drunkan, you've fixed the speedo, but the tacho looks like the reading is out of whack too. And what wheels and tyres are you running now? Pics please?
Oil change (my last bottle of GW Sougi s6000), and a yearly inspection of the turbo oil feed banjo. Was enlarged to 1.5mm last year.
Looks like I'll be changing to the new GW SYN-X 6000 for the next one.
I checked my banjo this week and it was squeaky clean. I didn't enlarge the size of it though.
Edited by slippylotion
Whether or not to enlarge seems to be a personal thing; to each his own. There's no question; it's cheap insurance to remove & inspect.thumbsup.gif
Autech 260RS
Stock bottom end
Stock FPR
Walbro fuel pump
Power FC
AVCR
Z32s
HKS 264 deg cams
HKS cam gears
HKS hard piping kit
Fujitsubo Cat back
Gutted cat
Turbosmart BOVs
312.5kW at 16.5 psi
272kW at 13 psi
Nice Build, bet its great to drive
I was just wondering how the Power FC goes with the 260RS, Im assuming you used the one specific for the R33 GTR/RB26
Did you have any issues getting it to work, does anything not work as its meant to.
from what i have read it "should" work fine in the stag but i have not asked anyone who has actually done it,
Thanks
Thanks
No problems here
Yeah mate that tacho is wierd....lucky mid 90s LCDs had such crap resolution. It consistently reads 500rpm high, not like the speedo that was a % wrong (ie wronger the faster you go)
I've got R34 GTR rims (finally clearning the brakes properly) and 255/40/18 Federals. No pics it's too wet :P
Also fit Z32 AFM today, total fail. SOmeone has played silly buggers with the Z32 AFM curve on my Powerfc and it's not running properly. I'll probably put the standard AFM back on until I can get a tune.
Thanks
I am running a R32 GTR PowerFC and the car runs fine, an R33 PowerFC would also work.
I Run a R33 PFC (on a R33 RB26) with almost identical setup, minus the inlet and hard piping kit, but I'm still around 20kw short of your power. Guess its time to order those Z32s and the Greddy kit then... thumbsup.gif Good to see whats possible with stock bottom end and turbos...
Found a little cubby hole for a oil catch can today. Hopefully will minimise the amount of oil going out the end of these bloody VQ's. Have to go to pirtek tomorrow and get some real hose- as usual the stuff they give you is massively shit.
you need one from an RS with hicas, or an ARX. but only vq25det
Not true. Pretty sure Craig said 350Z 5MT rear diff, but I'd have to check.
I think the VQ25DD front diff is the good one though, haven't double checked yet.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
