2 1/2" Suction pipe tacked together for a trial fit tomorrow, prior to purge welding.
Now we get to see how accurate my fab is. :whistling:
Nice and tight down there isn't it, I assume that's why you went with 2.5 inch?
Yep, sure is. Getting your 3" version through must be a good job.
I'm running it through the path taken by the original, and it's only about 6mm wider at the critical point than the OEM one.
I was able to use standard 316L mandrel bends, and I've got a pretty straight shot at the compressor wheel. The inlet on the compressor cover is 2 1/2", so it shouldn't be restrictive.
I've also hooded the Blow Off inlet merge into the suction pipe to hopefully avoid any reversion issues.
The piece I'm looking forward to changing is the section before that, but I don't have any more material (or time to be honest) atm.
Make sure you take some pics Dale - love to see what you've done. Could it be the prototype for a future manufacturing run...? :whistling:
Edited by Commsman
You all realise you will hit airflow cut with the intake done right? Read 'close up view of the windscreen" lol.
It's all downhill from there... :)
Haha, yes, it's a slippery slope - one thing leads to another....
Will do; lets see if it fits first...
Yay! Random windscreen headbutts eh? I love surprises! :woot:
Downhill or uphill? I'm hoping a little bit of bad might lead to some good. Might need to wait for my wallet to recover.
Mine's sitting at the tuner, waiting for tune: can't wait: going for a nice meaty midrange, and earlier spool-up: hopefully with the new turbo manifolds, suction kit and z32s, it should be a no-brainer. Last tune with stock manis, rb26 afm's and stock inlet, it made a safe 297awkw.
Will be interesting to see what happens if it doesn't explode... ;)
keep us posted. what turbs you running? Good luck
Been a productive weekend. Installed turbo side cam gasket, replaced in car filter and ran a 5m USB cable from tv tuner in boot to under front armrest so I don't have to go to boot all the time to change USB stick. Next thing to do is fix boot latch, fix exhaust bolt that I snapped and machine front rotors. All will be done by Friday in time for my trip to Sydney next Wednesday for world time attack next weekend. Tiltons Evo for the top honor!!
297kw atw's is impressive already. Isn't amazing how one becomes accustomed to the amount of power. Here I am with a maybe 150kw's at the wheels? and to think of doubling that and then wanting more seems almost crazy for a street car. But there it is. It only seems crazy until one becomes accustomed to it. anyhoo, i'm jealous :D gimme your cc details and i swear i'll feel better ;)
So I decided to knock up a gauge pod to mount a boost gauge on my dash at the base of the A-pillar the other day.
I started with a yum-cha '1 size fits all' generic A-pillar mount i got for cheap off eBay which i then started cutting into shape, followed by a bit of bogging & sanding
Pics:
And once I was happy with the shape (and many coats of hi-fill later), I painted it with some dark grey paint I had mixed up in a sample pot from Bunnings, applied with a sponge for the textured effect (the colour isnt a perfect match, but its close enough) & then stuck it to the dash with dounle sided tape
I'm in half a mind to re-do it so that the line at the bottom matches the line of the vent underneath it, but finding the time is the problem - that & the fact that I couldn't be arsed. :unsure:
That gauge pod is pretty cool, but did you consider trying to put it in the top vent hole? Nothing much goes in or out of there; I've had mine blocked for ages & noticed no difference.
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
