redo
garret 35r turbo
new thicker cooler [unsure of brand]
full 3.5inch stanless turbo back exhaust pipe
750cc injectors
Tomei poncam camshafts
and a retune
video
http://s1160.photobucket.com/albums/q494/r33huntme/?action=view&current=stagea002.mp4
Spent an hour or three pull off bits to get down to the knock sensor in the V of the block in my ARX. Computer attached to car to diagnose why it was running very rich and had retarded timimg came back with - "faulty knock sensor". Was assured by mechanic it was definitely faulty not a loose or otherwise bad connection.
Have a look at the attachment and you will see a nest made of firewall material and chewed conductors. The mouse trap is artistic licence.
Thanks to Scott I found my way down to the problem and now know a bit more about how it is put together. Hope not to have any left over parts when it goes back together tomorrow - once I repair the cable.
Looks like the sheath on the coaxial is cut at the plug end, joining it back should be enough but re shielding it would be best (somehow). Let me know if you want the spare knock cable expressed buddy.
Hahaha... Your not the first, and won't be the last to have a mouse nest in the valley. Pesky buggers.
My neighbour had a fire in the engine bay of a Camry the nest was built on the exhaust manifold.
redo
garret 35r turbo
750cc injectors
and a retune
video
http://s1160.photobu...t=stagea002.mp4
Have you got a plot with boost. I guess you have 260 deg poncams?
I didnt open the rest of the cable up enough to see it as coaxial. From what I can tell the black insulated cable is the core. The other seems to be the shield conductor but it is bundled in clear or pale coloured insulation for that last 5cm or so. For that last bit outside the flexible conduit it just looks like 2 insulated conductors, same colours at the other end. You can see a bit of the other conductor left at the plug and the cable
Thanks for the offer I will see how it goes. Only problems may be, the quality of the solder joins as was hard to get the conductors to "tin", and the tolerance of the insulation to the heat. I may have made the cable a few cm longer so that may have a impact as well. Feels like normal again driving, will see how the first tank goes.
Maybe there should be a rodent modifications topic?
My rodent nest was made from a 100mm by 100mm area of the fire wall insulation so at least it couldn't catch fire.
Installed a Koyorad full aluminium radiator, two 12'' davies craig thermo's with temp switch and custom aluminium shroud, big trany cooler and transgo shift kit to my M35 ARX over the weekend. Radiator is excellent - thermo's only need to switch on while idling after some time or high temp days every now and then. Radiator is so much more efficient. Transgo kit is absolutely fantastic!
Nice! Did you do the Transgo install yourself?
There's a nice controller on eBay for about $100.
Had a bit of fun today; started out bleeding some air out of my cooling system, and once I'd finished, dropped the bung for the rear bleed point down the back of the motor.
Ended up having to crawl halfway under the car to fish it out of the rear undertray...
I've also been waiting a week or so for my new HID globes, as one blew. Globes turned up this arvo, so I thought; why not?
Passengers side done, had to pop the airbox out, but no biggy. On to the driver's side, pulled out the coolant recovery bottle; globe changed, but I was using a torch by this stage.
In went the recovery bottle, and straight down went the torch.
Did it drop into the undertray? Nooooooooo; of course not! Hit the undertray, and bounced up and magnetised onto the top of the oil filter...
Had to drop half the undertray in the garage to retrieve it.
TL/DR?
Took 2 simple jobs, and turned them into epic displays of hamfistedness.
Farkin hate cars sometimes.
Edited by Daleo
^^hmm reminds me of changing the battery but dropping the wing nut and having it lodge/wedge itself behind the radiator necessitating loosening the top bolts and lifting the radiator up........but first spent 15mins shaking the undertray and looking everywhere for the bloody thing.
Lucky mate, I dropped mine in between the heatshield and the exhaust manifold, I had to leave it there.
I now have a ball valve at the bleed point, it makes purging the air simple with a funnel screwed in. ;)
Originally, that's where I thought it had gone; much swearing was done.
I saw pics of your setup; do you find the branch into the rear of the block simplifies bleeding?
Feel like making one for me? Price?
Hahaha... Number of times I've been saved by one of those extendable magnets when dropping stuff. Best tool for oafs.
One I couldn't find on the shitbox, was a tps clip. Sprung off never to see again. In that case cable ties ftw.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
