Waiting to see how badly scored the bores are, then it's on to ordering new pistons rods and incidentals.
Does anyone know if R33 GTR front strut braces fit a C34 S1 RSFour?
Also looks like I'll be getting the PFC EL commander to replace the oldschool, scratched unit I have moulded behing the gear stick: I may actually be able to read it... ;) between nasty scratched lens, and the heat from the trans tunnel, the LCD unit is Very hard to read on the fly...
R33 gtr strut brace should fit seeing my 260rs has one fitted from factory! Looks exactly the same as my mates on his gtr
Black vacuum hoses would have been stealthier :P
Blah blah blah :P
Fitted Scottys bastard cooling mod. Instructions and the whole sordid install tale to follow.
Blah blah blah :P
What was the problem Ryan? Bit messy if you are not flushing the coolant, but other than pretty straight forward, no?
I'll write it up tomorrow Cam, knackered now. I got photos of absolutely everything, and it will definately be an idiots guide to doing this.
So many things I wished I'd known in advance that will help the next person.
woohhoooo cheers Ryan :)
Got bored this arvo so I threw one of these in my car
But unfortunately I've imposed a ban on driving my car until some other parts arrive, which will hopefully be this week - and THEN I can find out if it makes any difference :ninja:
Put your car on a dyno in case the afrs and timing are all wrong. Presumably its not the tunable type?
Sooooo your the one that got that! I thought it went to LEKS! Bastard! :P
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
