Looks good Leon. How's the car going? Are you rebuilding or replacing the engine?
Replacing it. Much easier/cheaper, at least for me, but still patiently waiting for the engine. May play around with the old engine in the future - learn me some new skills.
Finally did the brake wire mod yesterday
Finally. :P
Have you ripped the heads off? Is the bore ok? I might be able to fix it if you want to sell it cheap enough.
It would be a shame to loose another engine, they are quite rare as you know. Are you importing one from Japan?
What happened mate?
No, haven't pulled anything apart but I did use an inspection scope & it looked OK. I think I just blew a ringland. I won't be tossing this out as I hope to rebuild it for a working spare. In the meantime it will be a good source for sensor swapping, if (when?) I find myself needing to diagnose something. Looked at importing thru JS but decided a local engine is less risky & cheaper. I've bought Darrin's now that he's not doing the swap into the C34. Will be more of a wait since he's in China buying stock for his spare parts business, but I'm not in too much of a hurry as mine is still driveable albeit smoky.
What happened mate?
See above. Essentially I was adjusting the AFM voltage to stop it droping off the edge of the map (had major AFM cutout) & thought I'd compensate by changing the fuel pump to full voltage. I think my pump didn't like it very much & was intermittently noisy, & I suspect it wasn't doing it's job properly. Leaned out on a cylinder & the rest is history....
I returned the pump to normal wiring & is quiet again. The silver lining is I can test stuff to my hearts content now that engine is already busted, lol.
shotgun turbo
Lol. I intend to have my current hi-flow rebuilt to new condition & then sell it with a swap with a standard turbo (blown up or not). Maybe the start of a turbo swap service??? In any case, my current one doesn't suit my driving preference so am looking forward to trying something different once the one on the new engine gives up the ghost.
Hi Guys, Im new to the stagea section i just brought a 2002 M35 VQ25dd RS a couple weekends ago for a stea $1500NZD. High KM's 280,000 worth. So it had a terrible cam chain stretch, sounded like a old type writer going to town under the bonnet. Anyhow yesterday i began to replace this timing chain. No wonder the local dealership said its worth more than the engine to replace them, the labour to get to it was 4 hours worth and a 10min job replacing the chain and guides. spent 30 mins cleaning up the sump front cover and all the mating faces of silicone.
People say you dont need to replace chains but this was a prime example of needing it done. As we took the cover off the chain nearly fell off the gears, the timing was out by a good couple degree's made starting really hard. the tensioner was at full and wasnt doing a thing, the top guide had worn down to the metal in the centre. and there was so much slack that the chain had gouged out grooves in the front and rear covers. I was very very close to having the pistons and valves go BOOM!
Got the new chain on and its all tight the cams were pulled back into line and comparing the new to the old its tight as a ......
Now we began reassembling the rest of the crap you have to take off to get to it. took 3 hours to get all the covers bolts and pumps back on, still have a hour or so to do tonight after work, getting the radiator, electrics and fluids back into the motor and then listen to the new girl purrrr.
sorry i didnt take any pictures of the old chain or the damage it cause to the covers, my hands were filthy and i wasnt going to handle my phone. i can take some photo's of the damages guide, that's about all.
this is what i brought for $1500NZD
Took some better photos to show the BOV control i rigged up to the original boost control solenoid. The control switch is mounted to the gear stick.
For anyone not quite sure what this does, it basically allows you to make the bov atmo or blocked/flutter by the switch.
Home made air ducting and shield for pod.
Stock solenoid and HDI solenoid
Plumbing
Gear shift switch
Now i am playing around with shock height and stiffness again, just to work out the last niggles in clearance. Fun fun fun !
Welcome. That's a good buy for that price. Any future mods to it? what part of Nz are you? Very helpful site if you want info in regards to Stagea's.
Thanks for the welcome, I'm from Cambridge. Only mods would be to lower it and maybe some wheels, it'l be the Mrs daily driver if i can sort it out. Got everything back in and started it up, there was a bit of a tapping sound when it was cold and then it not driven, once i took it for a drive the taping sound had gone. Do these have hydraulic lifters or solid, as i think it might be to do with the oil viscosity? if they're solid then i'm stumped and hope its not play between cold pistons.
Also i'm now having a starting issue which i thought the timing was out from the chain, but with that replaced its still hard to start. I'm wondering if its a faulty sensor or if the starter and everything is drawing to much current from a slightly old battery. Would the ecu or learnt that with the old chain and timing been so far out to drive like that. and now its back to factory it cannot start properly?
Have booked it in with a auto sparky to see if they can diagnose it next week. Yes this is by far the best site to get Stagea info from i have found out.
The cam tensioners take a fair while to fill with pressure once re-assembled, that would have been the noise you heard. Nothing to worry about unless it doesn't go away. The workshop manual says to rev it to 3k and hold it for 5 minutes to bleed the tensioners. The valve gear has solid buckets, some are shimmed and some aren't.
If it's hard to start, try a new battery first. If you still have issues, is there an engine light up? Most of the faults will throw a code.
I guess it depends on how you want to lower it, I've noticed here they seems to go coilovers rather than changing springs. Personally I want to go coilovers but, the car has to be certified afterwards so the costs escalate. The majority of sellers on TradeMe seems to recommend JAMEX lowering springs, due to limited options availability for M/PNM35 when it comes to springs???? can someone prove them wrong.
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
